The Ping360 sonar is a mechanical scanning sonar. When mounted on a BlueROV2 and using the Ping-Viewer software application, a Ping360 can be used for navigation in low-visibility water conditions, inspection, obstacle avoidance, target location and tracking. You can see echoes from objects like ropes, walls, dock pilings, rocks, shipwrecks, boats, and any other structures or objects that reflect sound waves. With that, you have reference points to navigate from, regardless of water visibility, and you can locate important features in the water quickly.
This guide will show you how to install the Ping360 onto your BlueROV2 using the default USB interface or the optional Ethernet interface.
updatedPing360 Scanning Imaging Sonar
Navigation and imaging sonar for BlueROV2 and other ROVs$2,750.00 -
- 1 x Sharpie or other type of marking pen (not included)
- 1 x 5.50mm (or 7/32”) drill bit (not included)
- 1 x Battery Powered Hand Drill (not included)
Additional Parts for Ethernet Connection
Ping360 comes ready to install in a BlueROV2 using the default USB connection. The Ping360 can also be installed using the Ethernet interface. To install the Ping360 using the Ethernet interface, you will also need the Blue Robotics Ethernet Switch and it will need to be installed in your BlueROV2.
Removing a Blank Penetrator
Install Ping360 Penetrator
To install Ping360 into the end cap, you will need the following parts and tools:
- 1 x Ping360 Scanning Sonar
- 1 x Penetrator Nut (Red)
- 1 x Penetrator O-ring
- 1 x Isopropyl Alcohol Wipe
3. Install the O-ring onto the Ping360 cable penetrator.
4. Install the Ping360 cable penetrator into the end cap in the hole you previously removed the blank penetrator from. Tighten to finger tight, then use the wrench to tighten it an additional ~1/16 of a turn. If you can’t loosen it with your fingers, it is tight enough.
Connecting The Power Wires
To connect the Ping360 power wires, you will need:
- #2 Phillips screwdriver
1. Connect the power wires (red and black wires) into open screw terminals on the respective positive and negative terminal blocks.
Wiring Connections for USB
To install the Ping360 wires into your BlueROV2 via USB, you will need the following components:
- 1 x JST-GH to JST-GH inline connection board
- 1 x JST-GH to USB cable
1. Plug the JST-GH connector coming from the Ping360 cable into the JST-GH to JST-GH inline connection board.
2. Plug the JST-GH to USB cable into the other end of the JST-GH to JST-GH inline connection board.
3. Plug the JST-GH to USB cable (USB side) into one of the open USB ports on the Raspberry Pi.
Wiring Connections for Ethernet
To install the Ping360 wires into your BlueROV2 via Ethernet, you will need the following components:
- 1 x Blue Robotics Ethernet Switch
- 1 x 200mm JST-GH to JST-GH twisted pair cable (from Ethernet Switch kit)
1. If the Ethernet Switch is not already installed in your BlueROV2, install it now by following the Ethernet Switch Installation guide. Once that is complete, return to this guide.
2. Switch the internal communication interface in the Ping360 from USB to Ethernet by following the instructions in the Changing Communications Interface on the Ping360 guide. When you are done switching the interface to Ethernet and the Ping360 is fully reassembled, come back to this guide.
3. Plug the JST-GH connector coming from the Ping360 cable into the JST-GH to JST-GH inline connection board.
4. Plug the 200mm JST-GH to JST-GH twisted pair cable into the other end of the JST-GH to JST-GH inline connection board.
5. Connect the other end of the JST-GH to JST-GH twisted pair cable to one of the open JST-GH ports on the Ethernet Switch. Do not use ports 1 or 5 as these are already in use.
Mounting the Ping360 to the BlueROV2 Frame (Standard)
To mount the Ping360 to the BlueROV2 frame, you will need the following parts and tools:
- 1 x Ping360 Mounting Bracket
- 4 x M3 x 5 button head cap screws
- 2 x M5 x 12 button head cap screws
- 1 x Marking pen
- 1 x 5.50mm (or 7/32″) drill bit (not included)
- 1 x 2 mm hex driver
- 1 x 3 mm hex driver
1. Pick which side you wish to install the Ping360 on your BlueROV2, port or starboard. For this guide, starboard was chosen.
2. Thread an M5 x 12 screw into the aft-most hole of the mounting bracket. Insert the assembly into the forward-most M5 hole on the BlueROV2 frame. Adjust the bracket so it is level and straight and mark the forward hole location with a Sharpie or marking pen.
3. Remove the bracket assembly and remove the M5 x 12 screw.
4. With a battery powered hand drill and 5.50mm (or 7/32″) drill bit, drill a straight hole in the marked position.
5. Secure the bracket to the base of the Ping360 using the M3 x 5 mm screws.
6. Secure the bracket to the BlueROV2 frame with the M5 x 12 screws.
Mounting the Ping360 to the BlueROV2 Frame (Heavy)
- 4 x M3x5 button head cap screws
- 2 x M5x12 button head cap screws
2. With a battery powered hand drill and 5.50mm (or 7/32″) drill bit, drill out the M4 holes in the middle of the frame. This will make it easier to install the mount.
3. Secure the bracket to the base of the Ping360 using the M3 x 5 mm screws.
4. Secure the bracket to the BlueROV2 frame with the M5 x 12 screws.
To clean up the external Ping cable, you will need several zip ties and your scissors/wire cutters.
The primary goal of cable management is to prevent the wires from getting cut by the propellers. Make sure to check that no wires can reach the propellers after you have finished routing the Ping360 cable.
Reinstall Buoyancy Blocks and Fairings
- 7 x 200g Ballast weights (from original BlueROV2 Kit)
- 7 x 8-16 Thread, 5/8” Long, Thread-Forming Screws
To get the longest battery life and the best driving experience, it is important to have the ROV close to balanced from front to back in water and close to neutrally buoyant. Ping360 is 175g negatively buoyant in water, so depending on placement, the ROV will need to be re-trimmed based on your operating conditions. Trimming the ballast may involve a bit of trial and error.
Software Update
Use With Ping Viewer Software - USB Configuration
The most recent stable release of Ping Viewer is required.
1. With the Ping360 fully installed in the BlueROV2, power on the BlueROV2 and make sure you are able to establish a connection.
2. Open Ping Viewer, the Ping360 should show up in the Device Manager list after a few seconds.
3. Select the Ping360 from the list, the sonar display and scanning should automatically start.
Main Ping-Viewer Interface Window
Use With Ping Viewer Software - Ethernet Configuration
Ping Viewer version 2.4.1 or newer is required. Get the most recent stable release of Ping Viewer here.
2. Open Ping Viewer, the Ping360 should show up in the Device Manager list after a few seconds with a blue status icon indicating that additional configuration is required.
3. Open the Network Configuration menu and select “Static IP” from the dropdown list.
4. Enter an IP address for the Ping360 that is on the same subnet as the BlueROV2 and your topside computer. If you are using the default BlueROV2 network settings this should be “192.168.2.__”, the default choice of “192.168.2.4” works fine on most networks.
Configuring Your Firewall
Windows Firewall
1. Go to Control Panel > Windows Firewall and then select “Allow an app or feature through Windows Firewall”.
2. Select “Change Settings” and then select “Allow another app…”.
3. In the next screen, select “Browse…”, navigate to the Ping Viewer folder and select the “pingviewer.exe” file. Finish by selecting “Add” to add it to the list of allowed apps.
MacOS Firewall
1. Follow the instructions here to allow Ping Viewer through the MacOS firewall.
Ping-Viewer does not connect to the onboard Ping360
1. Recheck the Ping360 wiring harness going to the Raspberry Pi.
2. Check to make sure you have the most recent release of Ping Viewer.
3. If using the Ethernet interface, ensure the IP address for the Ping360 is configured correctly and the Ping Viewer software is allowed through your computer’s firewall. Try pinging the Ping360 at its configured IP address. If there is no response, check the network configuration.
4. Contact our support team for further troubleshooting recommendations.
