Price range: $5.00 through $8.00
This WetLink Penetrator Blank is used to seal any unused holes on your watertight enclosure with a high-pressure seal. Each set includes a bulkhead, O-ring, and nut. It’s rated to 1000 meter (3,280 feet) water depth! We recommend the Bulkhead Wrench for easy installation!
U.S. customers will be charged a tariff surcharge of $0.60 - $0.96 for this product. Learn more
Quantity 1 - 4 5 - 19 20 - 49 50 - 99 100 - 199 200 - 1000
Price Price range: $5.00 through $8.00 Price range: $4.50 through $7.20 Price range: $4.25 through $6.80 Price range: $4.00 through $6.40 Price range: $3.75 through $6.00 Price range: $3.50 through $5.60
SKU: WLP-BLANK-VP
HS Code: 7616.10.7030
This cable penetrator blank is provided with no hole. You can use it to seal an extra hole on a watertight enclosure! This blank features a hex socket for ease of installation!
The WetLink Penetrator (WLP) is our patent-pending, next-generation solution for low-cost, high pressure, high reliability sealing of electrical cables as they pass into enclosures or other devices. It’s rated to a depth of 1000 meters (3,280 feet) and compared to subsea connectors or penetrators, the WetLink Penetrator is a fraction of the cost while offering validated reliability that you can count on.
CAD model is of the M10 thread.
For each unit, the following items are included for the selected cable diameter size and bulkhead size.
  • 1 x WLP Blank Bulkhead
  • 1 x WLP Nut
  • 1 x O-Ring
ParameterM06 ThreadM10 ThreadM14 Thread
Part NumberBR-100434-006BR-100434-010BR-100434-014
Performance Characteristics
Maximum Rated Depth (seawater)1000 m / 3280 ft
Design Lifetime¹3 years or 500 cycles to rated depth
Temperature Rating-40 to 60°C / -40 to 140°F
Tools
Compatible Bulkhead WrenchBR-100977-006BR-100977-010BR-100977-014
Physical
Bulkhead Thread SizeM6M10M14
Bulkhead Thread Pitch1 mm1.5 mm1.5 mm
Bulkhead/Nut Wrench Flats12 mm16 mm20 mm
Hex Key3 mm6 mm6 mm
O-ring Size1.5 x 7 mm Buna-N 70AAS568-013 Buna-N 70A1.5 x 15 mm Buna-N 70A
Overall Assembled Height from Endcap6 mm8 mm8 mm
Overall Thread Length 10 mm20 mm25 mm
Overall Outer Diameter13 mm18 mm22 mm
Recommended Through Hole Size6.2 mm10.2 mm 14.2 mm
Bulkhead MaterialAluminum 7075-T6, type III anodized
In Air Weight (no nut)2.3 g6.6 g11.8 g
In Water Weight (no nut)1.5 g4.2 g9.3 g
Recommended Installation Torque (bulkhead or nut)1 N⋅m3.5 N⋅m3.5 N⋅m
¹ Design life was used to inform testing in an accelerated environment, does not reflect warranty period.
WL-M06-BLANK-PUBLIC (.zip)
WL-M06-NUT-R1 (.zip)
WL-M10-BLANK-PUBLIC (.zip)
WL-M10-NUT-R1 (.zip)
WL-M14-BLANK-R1 (.zip)
WL-M14-NUT-R1 (.zip)
24 March 2025
  • BR-100434-006, M06 Thread – Changed to type III anodizing
20 January 2025
  • BR-100434-010, M10 Thread – Changed to type III anodizing
21 November 2024
  • BR-100434-014, M14 Thread – Changed to type III anodizing
[/rev]
20 June 2023
  • WL-M06-BLANK-R1-RP SKU changed to BR-100434-006
  • WL-M10-BLANK-R1-RP SKU changed to BR-100434-010
  • WL-M14-BLANK-R1-RP SKU changed to BR-100434-014
1 February 2023
  • Bulkhead O-ring color changed to blue
25 January 2022
  • WL-M14-BLANK-R1-RP - Initial release
8 September 2021
  • WL-M06-BLANK-R1-RP - Initial release
  • WL-M10-BLANK-R1-RP - Initial release
WetLink Penetrator Assembly and Installation
This guide will show you how to assemble and install a WetLink Penetrator.
Blue Robotics Forums – WetLink Products
