These configurable 2″, 3″, 4″, 5″, 6″, and 8″ subsea housings are great for use on ROVs, AUVs, harsh environment sensing, and other marine robotics applications. Modular end caps give you options – dome, blank, and with holes for cable penetrators. Depth ratings are shown for each component in the dropdown and all technical details can be found below.
We’ve identified an issue with the latest version of aluminum tubes that reduces their rated depth by 50%. These tubes can be identified by the two large grooves cut into the inner diameter of the tube. Aluminum tubes are temporarily derated until redesigned tubes are available. Please refer to this technical bulletin for more information.
Configure your enclosure here:
SKU: WTE-VP Categories: ,
HS Code:
Country of Origin:
Meet our second generation 2″, 3″, 4″, 5″, 6″, and 8″ Series watertight enclosures for ROVs, AUVs, marine vehicles, and other harsh environments. They’re completely configurable with a variety of tube and end cap options offering a substantial upgrade over the first generation of watertight enclosures. Precision machined O-ring interfaces, a locking cord and anti-rotation feature to secure the flange, and smooth O-ring lead-in make these enclosures a perfect fit for a wide range of applications including MATE and Robosub ROVs, subsea batteries, cameras, electronics, data loggers, environmental monitoring, instrument housings, junction boxes, and more.
When used with the clear acrylic plastic tube option, it’s easy to see the components inside the enclosure, ideal for subsea development projects and research ROVs and AUVs. The aluminum tube option provides a greater depth rating, opaque appearance, and better thermal transfer for high power applications like power supply housings and battery housings.
Precision machined tube ends.
Precision Machined O-ring Interface on the Tubes
The acrylic tubes are cast optically clear material, like the previous generation, but the inner ends are now precision machined so that despite wide tolerances on the raw plastic material, the O-ring interface is always manufactured to tight tolerances. The aluminum tube options are also precision machined for an excellent fit. A smooth surface finish ensures proper sealing between the O-ring flange and the tube and a smooth O-ring lead-in shape makes it easy to insert the flange without damaging the O-rings.
Because of the precision machined interface, the tubes are no longer available in custom lengths, however we have several different length options for each diameter, representing the most popular lengths of custom tubes that were ordered in the past.
Anti-Rotation Feature
The tubes have a slot machined at each end that provides access to insert and remove the locking cord. That slot doubles as the mating point for a key that is machined into the flange. The key inserts into the slot so that the flange can only be installed in one orientation, preventing the end cap or flange from being rotated and damaging internal components.
Tube with flange installed.
Tube and flange with the locking cord installed.
Locking Cord
The locking cord is a new feature in this generation of watertight enclosures. The locking cord allows you to secure the flange to the tube so that they cannot be separated unless the cord is removed. There’s a half-circle shape machined into the inside of the tube and a matching half-circle shape machined into the flange. Once assembled, a round plastic locking cord is inserted into the circular space, preventing the flange from being removed from the tube.
The locking cord is included with the enclosure and comes with a small anodized aluminum handle that can be attached to make the cord removal as easy as possible. Alternatively, if you want to make the enclosure tamper-resistant, you can cut off the cord and cover the insertion slot. This is suitable for finished products that are not intended to be opened by the user.
Combined Flange Cap Design
Exclusively for the 2″ Series enclosure is a shift to combining the sealing flange and end cap into one part: the flange cap. While the flange seal is still available to handle the clear, dome, and custom end caps, the flange caps offer a combined solution that does not require any screws or assembly. There are zero, two, and four hole versions of the flange cap with threaded M10 holes to suit our cable penetrators.
Configuring Your Enclosure
The watertight enclosures are available through this configuration page, which lets you select a tube, flanges, end caps, vent, and more. You can also purchase components separately if you prefer.
When you’re done configuring your enclosure, head over to RAILS to setup a custom electronics tray system for your components.
Locking Cord
CAD model demonstrates one possible configuration.
All required components for a complete watertight enclosure, excluding penetrator bulkheads, are included. For a detailed list of everything that is included with each component, please visit the individual product pages linked below.
¹An O-ring flange must be selected in the configurator when selecting end caps. A flange is not required and will not be selected when selecting the flange cap option for the 2″ series enclosures.
 Drawing
Tubes
These depth ratings are for acrylic tubes and aluminum tubes not affected by racking groove derating. See table below for derated depth limits.
Series DiameterTube Material/FinishTube ID (A)Tube OD (B)Overall Length¹ (C)WeightDepth Rating ²Part Number
50 mm
(2")
Aluminum 6061-T6, type III anodized50.0 ± 0.5 mm58.0 ± 0.2 mm100 mm169 g1000 mBR-100534-100
150 mm261 gBR-100534-150
300 mm536 gBR-100534-300
Cast Acrylic49.5 ± 1.5 mm58.0 ± 0.5 mm
100 mm75 g225 mBR-100230-101
150 mm115 g130 mBR-100230-151
300 mm238 g100 mBR-100230-301
75 mm
(3")
Aluminum 6061-T6, type III anodized79.0 ± 0.5 mm86.5 ± 0.3 mm150 mm328 g1000 mBR-100611-150
240 mm530 gBR-100611-240
300 mm665 g900 mBR-100611-300
400 mm890 g750 mBR-100611-400
Cast Acrylic76.2 ± 2.0 mm88.9 ± 0.7 mm150 mm264 g275 mBR-102649-150
240 mm442 g150 mBR-102649-240
300 mm560 g135 mBR-102649-300
400 mm758 g120 mBR-102649-400
100 mm
(4")
Aluminum 6061-T6, type III anodized103.0 ± 0.5 mm112.0 ± 0.3 mm200 mm707 g1000 mBR-100195-200
300 mm1066 gBR-100195-300
400 mm1426 g800 mBR-100195-400
Cast Acrylic101.6 ± 2.1 mm114.3 ± 0.8 mm200 mm488 g140 mBR-101052-200
300 mm746 g100 mBR-101052-300
400 mm1004 g60 mBR-101052-400
130 mm
(5")
Aluminum 6061-T6, type III anodized130 ± 0.5 mm138.7 ± 0.3 mm300 mm1450 g1000 mBR-101409-300
500 mm2441 g500 mBR-101409-500
150 mm
(6")
Aluminum 6061-T6, type III anodized150 ± 0.5 mm163.9 ± 0.3 mm300 mm2510 g1000 mBR-101411-300
500 mm4360 gBR-101411-500
200 mm
(8")
Aluminum 6061-T6, type III anodized200 ± 0.5 mm214.2 ± 0.3 mm300 mm3420 g1000 mBR-101412-300
500 mm5915 gBR-101412-500
¹ Overall length tolerance is ± 0.5 mm.
² The depth ratings for cast acrylic components are applicable only for short-term submersions lasting less than two weeks. For longer submersion, we suggest using aluminum components only.
The depth limits below are for aluminum tubes affected by racking groove derating.
50 mm
(2")
Aluminum 6061-T6, type III anodized50.0 ± 0.5 mm58.0 ± 0.2 mm100 mm169 g500 mBR-100534-100
75 mm
(3")
Aluminum 6061-T6, type III anodized79.0 ± 0.5 mm86.5 ± 0.3 mm150 mm328 g500 mBR-100611-150
300 mm665 g450 mBR-100611-300
400 mm890 g375 mBR-100611-400
100 mm
(4")
Aluminum 6061-T6, type III anodized103.0 ± 0.5 mm112.0 ± 0.3 mm200 mm707 g500 mBR-100195-200
400 mm1426 g400 mBR-100195-400
130 mm
(5")
Aluminum 6061-T6, type III anodized130 ± 0.5 mm138.7 ± 0.3 mm300 mm1450 g500 mBR-101409-300
500 mm2441 g250 mBR-101409-500
150 mm
(6")
Aluminum 6061-T6, type III anodized150 ± 0.5 mm163.9 ± 0.3 mm300 mm2510 g500 mBR-101411-300
200 mm
(8")
Aluminum 6061-T6, type III anodized200 ± 0.5 mm214.2 ± 0.3 mm300 mm3420 g500 mBR-101412-300
² Temporary derating for aluminum tubes with racking grooves.
Flanges
Series DiameterFace Seal O-ringRadial Seal O-ringFlange OD (E)Piston Diameter (F)Piston Length (G)Overall Length (H)Inner Mounting Hole Circle (J)WeightPart Number
50 mm (2")-030
Buna-N 70A
-031
Buna-N 70A
58.0 ± 0.1 mm50.95 ± 0.05 mm15.5 ± 0.1 mm21.5 ± 0.1 mm43.0 ± 0.1 mm41 gBR-100628-998
75 mm (3")-148
Buna-N 70A
-150
Buna-N 70A
88.9 ± 0.1 mm79.95 ± 0.05 mm19.1 ± 0.1 mm27.0 ± 0.1 mm68.6 ± 0.1 mm81 gBR-100647
100 mm (4")-154
Buna-N 70A
-154
Buna-N 70A
114.3 ± 0.1 mm103.95 ± 0.05 mm19.1 ± 0.1 mm27.0 ± 0.1 mm94.0 ± 0.1 mm107 gBR-100665
130 mm (5")-157
Buna-N 70A
-248
Buna-N 70A
137.7 ± 0.1 mm130.45 ± 0.05 mm28.0 ± 0.1 mm34.0 ± 0.1 mm115.0 ± 0.1 mm238 gBR-102200
150 mm (6")-162
Buna-N 70A
-255
Buna-N 70A
165.4 ± 0.1 mm156.45 ± 0.05 mm30.0 ± 0.1 mm36.0 ± 0.1 mm142.0 ± 0.1 mm308 gBR-102201
200 mm (8")-170
Buna-N 70A
-265
Buna-N 70A
215.7 ± 0.1 mm205.95 ± 0.05 mm36.0 ± 0.1 mm42.0 ± 0.1 mm186.0 ± 0.1 mm540 gBR-102202
Material: Aluminum 6061-T6, type III anodized for all flanges
Locking Cord Diameter (D): 2.6 ± 0.4 mm for all flange sizes
Inner Mounting Holes (I): M3x0.5 for all flange sizes
End Caps
Series DiameterMaterialHole ConfigurationEnd Cap ScrewsEnd Cap Screw Hole Circle (K)Thickness ¹ (L)WeightDepth Rating ²Part Number
50 mm
(2")
Cast AcrylicBlank (No holes)M2x0.4-10Ø50.8 ± 0.1 mm6 mm [+0.63, -1.15]17 g500 mBR-100094
Aluminum 6061-T6, type III anodizedBlank (No holes)Note: flange integral to end cap, does not
require separate flange.
63 g1000 mBR-100276-999
2x M10 Thru59 gBR-100276-002
4x M10x1.5 Threaded58 gBR-100276-004
1x M10 Thru
8x M06x1 Threaded
60 gBR-100276-009
75 mm
(3")
Cast AcrylicBlank (No holes)M3x0.5-12Ø82.6 ± 0.1 mm9 mm [+0.75, -1.53]58 g400 mBR-100949-998
Aluminum 6061-T6, type II anodizedBlank (No holes)Ø82.6 ± 0.1 mm6 mm102 g1000 mBR-100949-999
4x M10 Thru6 mm97 gBR-100949-004
7x M10 Thru6 mm93 gBR-100949-007
100 mm
(4")
Cast AcrylicBlank (No holes)M3x0.5-16Ø108.0 ± 0.1 mm12.7 mm [+0.05, -2.5]135 g300 mBR-102993-998
Aluminum 6061-T6, type II anodizedBlank (No holes)M3x0.5-1210 mm234 g1000 mBR-102993-999
5x M10 Thru10 mm223 gBR-102993-005
10x M10 Thru10 mm212 gBR-102993-002
7x M10 Thru
11x M10x1.5 Threaded
10 mm196 gBR-102993-003
1x M10 Thru
4x M14 Thru
10 mm215 gBR-102993-004
2x M10 Thru
8x M14 Thru
10 mm195 gBR-102993-006
5x M10 Thru
2x M10x1.5 Threaded
8x M14x1.5 Threaded
10 mm186 gBR-102993-007
130 mm
(5")
Aluminum 7075-T6, type II anodizedBlank (No holes)M3x0.5-12Ø133.0 ± 0.1 mm10 mm427 g1000 mBR-102203-001
Aluminum 7075-T6, type III anodized5x M14 Thru
5x M10 Thru
393 gBR-102203-002
Aluminum 7075-T6, type II anodized10x M14 Thru
7x M10 Thru
367 gBR-102203-003
11x M10 Thru
15x M10x1.5 Threaded
369 gBR-102203-004
150 mm
(6")
Cast AcrylicBlank (No holes)M3x0.5-16158.7
± 0.1 mm
12.7 mm [+0.05, -2.5]331 g150 mBR-102205-007
II anodized
Blank (No holes)M3x0.5-126 mm359 g150 mBR-102205-006
5x M10 Thru353 gBR-102205-005
15x M10 Thru339 gBR-102205-004
Aluminum 7075-T6, type III anodizedBlank (No holes)M3x0.5-12158.7 ± 0.1 mm12 mm687 g1000 mBR-102205-001
Aluminum 7075-T6, type II anodized5x M10 Thru
5x M14 Thru
647 gBR-102205-002
16x M14 Thru
13x M10 Thru
566 gBR-102205-003
200 mm
(8")
Cast AcrylicBlank (No holes)M3x0.5-16209.1
± 0.1
12.7 mm [+0.05, -2.5]564 g75 mBR-102206-007
II anodized
Blank (No holes)M3x0.5-126 mm599 g75 mBR-102206-006
III anodized
5x M10 Thru592 gBR-102206-005
Aluminum 7075-T6, type II anodizedBlank (No holes)M3x0.5-12209.1 ± 0.116 mm1458 g1000 mBR-102206-001
5x M10 Thru
5x M14 Thru
1370 gBR-102206-002
10x M10 Thru
10x M14 Thru
1283 gBR-102206-003
16x M14 Thru
14x M10 Thru
1191 gBR-102206-004
¹ Overall thickness tolerance ± 0.1 mm.
Domes
Series DiameterMaterialDome Internal Radius (M)Dome Wall Thickness (N)ScrewsWeightDepth RatingPart Number
50 mm (2")Hardened polycarbonate dome
Polycarbonate (30%GF) retaining ring
18.0 ± 0.1 mm2.50 ± 0.10 mmM2x0.4-1015 g1000 mBR-100859
75 mm (3")31.25 ± 0.10 mm3.1 ± 0.1 mmM3x0.5-1239 g750 mBR-101059
100 mm (4")43.5 ± 0.1 mm3.75 ± 0.10 mmM3x0.5-1281 g500 mBR-100495
130 mm (5")53.5 ± 0.057.00 ± 0.05M3x0.5-12195 g600 mBR-102597
Please see the tubes, flanges, and end caps component product pages for links to 3D models.
Please see the tubes, flanges, and end caps component product pages for complete revision history.
7 February 2024
  • WTE5-VP - Initial release
  • WTE6-VP - Initial release
  • WTE8-VP - Initial release
18 May 2022
  • WTE3-VP - Initial release
  • WTE4-VP - Initial release
19 November 2019
  • WTE2-VP - Initial release
Learn how to assemble and use a Watertight Enclosure!
Watertight Enclosure RAILS User Guide
Learn how to configure a RAILS system and install it in your Watertight Enclosure!
Learn how to install the PRV on your watertight enclosure and use its related accessories!
Fighting Galvanic Corrosion with Zinc and Tef-Gel
Learn how to protect from galvanic corrosion through a combination of isolation via lubricant and use of a sacrificial anode—zinc!
The standard thread for most Subconn and Seacon type “MCIL” connectors is 7/16"-20. The 10mm holes in the end-cap are the perfect size to be tapped for that threading. A tap like this one can be used to make the proper threads. Depending on the endcap, some holes are spaced closer together, preventing the installation of two connectors immediately adjacent.
