$11.00$32.00 / meter
These cables are built specifically for use underwater and used in our products! A polyurethane jacket, PTFE tape, and FEP insulated conductors make for a rugged cable that can carry a lot of power. Sold by the meter (3.3 ft) and cut to length when you order.
Product Price
U.S. customers will be charged a tariff surcharge of $1.32 - $3.84 for this product. Learn more
SKU: CAB-PUR-FEP-VP
HS Code: 8544.11.0050
These cables are built for a wide range of subsea applications and designed to carry high currents underwater. The cables are custom made with a pressure-extruded polyurethane jacket, and flexible conductors. Each conductor is insulated with FEP, which can handle high temperatures without melting, and chemically etched to ensure excellent adhesion to potting compounds and glues. They’re really tough and abrasion resistant!
These cables are used in the T200 Thruster, T500 Thruster, the Ping360 Sonar, and in countless other applications!
  • 1x Selected cable with bare ends, cut to length
CableHigh Power CableT200 CableT500 CablePing360 Cable
Construction2-conductors, tape wrap, jacket3-conductors, tape wrap, jacket3-conductors, fabric wrap, jacket3-unshielded twisted pairs, tape wrap, jacket
Diameter8.3 mm6.4 mm9.0 mm5.5 mm
Outer JacketPressure-extruded polyurethanePressure-extruded polyurethanePressure-extruded polyurethanePressure-extruded polyurethane
WrapPTFE tapePTFE tapeNonwoven fabricPTFE tape
Filler----
Number of Conductors2336
Conductor Gauge12 AWG16 AWG12 AWG26 AWG
Conductor InsulationFEPFEPFEPFEP
Conductor Insulation ColorsRed, blackWhite, green, blueWhite, green, blueblack, red
orange, orange/white
green, green/white
Static Minimum Bend Radius26 mm18 mm30 mm20 mm
Compatible WetLink PenetratorM10-8.5mm-LCM10-6.5mm-LCM14-9.5mm-HCM10-5.5MM-LC
15 July 2025
  • BR-101529, Ping360 Cable – Initial release
    • Cable diameter increased from 4.7 mm to 5.5 mm
    • Conductor gauge increased from 28 AWG to 26 AWG
  • BR-100614, Ping360 Cable – Retired
18 July 2023
  • CAB-PUR-3UTP-28AWG-R2 SKU changed to BR-100614
  • CAB-PUR-3-12AWG-R1 SKU changed to BR-100235
  • CAB-A-2-12AWG-R1 SKU changed to BR-101093
6 April 2023
  • CAB-PUR-3-16AWG-R2 SKU changed to BR-100997
16 September 2022
  • CAB-PUR-3-12AWG-R1 – Initial release
2 December 2021
  • CAB-PUR-3UTP-28AWG-R2 – Initial release
12 February 2021
  • CAB-PUR-3-16AWG-R2 – Initial release
3 June 2016
  • CAB-A-2-12AWG-R1 – Initial release
Cable Stripping
Learn how to properly strip cables for use with WetLink Penetrators!
WetLink Penetrator Assembly and Installation
This guide will show you how to assemble and install a WetLink Penetrator.
Potting a Cable Penetrator
Learn to pot the perfect penetrator to pass a cable into your watertight enclosure!
Community
Blue Robotics Forum
