Our second-generation series of Watertight Enclosures are completely configurable with a variety of tube and end cap options making them a perfect fit for a wide range of applications. This guide will show you how to assemble and use your Watertight Enclosure.
General Information and Safety
To ensure safe operation, the Pressure Relief Valve should be installed on all watertight enclosures when using the locking cord.
Always inspect the O-rings before operation in water and especially when replacing the end caps, aluminum flanges, or bulkheads. Any dust, hair, or other particles can cause a leak.
Use plastic tools, NOT steel or other hard tools, to remove the O-rings from the aluminum sealing flange. Hard tools may scratch the material and compromise sealing ability.
Most threadlockers are not chemically compatible with plastic and will damage acrylic parts or the dome retaining ring.
Only clean the dome and acrylic tubes with plain water or an acrylic-safe cleaner. Alcohol, solvents, and harsh cleaners will craze and damage the material.
Using a Pressure Relief Valve or Vent
Every Watertight Enclosure should have a vent or Pressure Relief Valve (PRV) installed. This allows the enclosure to release pressure while being opened or closed. It is strongly recommended to use a Pressure Relief Valve for safety when using the enclosure with a locking cord. The locking cord is used to secure the flanges to the tube, preventing accidental detachment. However, this additional security means that if an excessive amount of pressure builds up inside the tube, it can create an unsafe situation. The Pressure Relief Valve is designed to automatically release any internal pressure in the enclosure in a safe manner.
Learn how to install the PRV on your watertight enclosure and use its related accessories!
WTE Vent Assembly Guide
Quickly assemble a vent for your WTE project!
Bulkhead Sizes
The Watertight Enclosure end caps are available in different hole configurations with M10-size holes, M14-size holes, or both. Be sure to select the correct end cap hole configuration and bulkhead sizes for your application.
M10 Holes
Most Blue Robotics products with preinstalled bulkhead penetrators use M10-size bulkheads and require an M10 end cap hole.
M10 bulkheads can be installed using the M10 size Bulkhead Wrench or a 16 mm wrench.
M14 Holes
M14 end cap holes support larger M14 size bulkhead penetrators. Currently, the T500 Thruster and the 9.5MM size WLP are the only Blue Robotics products that use an M14 size bulkhead.
M14 bulkheads can be installed using the M14 size Bulkhead Wrench or a 20 mm wrench.
Long-term Submersion
For long-term submersion of greater than two weeks, we recommend using aluminum Watertight Enclosure components only. The depth ratings for cast acrylic components are applicable only for short-term submersions lasting less than two weeks.
Parts and Tools for Assembly
Hex driver sizes:
  • 1.5 mm hex for 2″ series enclosures
  • 1.5 mm and 2.5 mm hex for 3″, 4″, 5″, 6″ and 8″ series enclosures
Assembling the Enclosure
1. Inspect the machined inner ends of the enclosure tube, the O-ring grooves on the flanges, and the end caps to make sure they are free of scratches or other damage.
2. Apply an even layer of silicone grease to both inner ends of the tube.
wte-guide-assembly-1
3. Apply a thin, even layer of silicone grease to the flange/flange cap O-rings and install them onto the flange or flange cap. Regular flanges use two radial seal O-rings and one face seal O-ring. The 2″ series flange caps use only two radial seal O-rings.
wte-guide-assembly-2
O-ring Sizes
The 3″, 5″, 6″, and 8″ series flanges use different O-ring sizes for the face and radial seals. Be sure to use the smaller O-ring for the face seal during assembly. For the 2″ and 4″ series flanges, the face seal O-rings are the same size as the radial seal O-rings. The O-ring sizes for each seal are provided below for reference. Replacement O-ring sets are available here.
Series DiameterFace Seal O-ringRadial Seal O-ringMaterialHardness
50 mm (2")AS568-030AS568-030Buna-N70A
75 mm (3")AS568-148AS568-150Buna-N70A
100 mm (4")AS568-154AS568-154Buna-N70A
125 mm (5")AS568-157AS568-248Buna-N70A
150 mm (6")AS568-162AS568-255Buna-N70A
200 mm (8")AS568-170AS568-265Buna-N70A
4. Install the end cap or dome onto the flange using the socket cap screws and a hex driver. Install all the screws loosely first then fully tighten the screws in a criss-cross (star) pattern. Skip this step if you have a 2″ series flange cap.
The 5″, 6″, and 8″ series enclosures may include a couple of extra end cap screws. These are spares and not needed for assembly.
wte-guide-assembly-3
Proceed with installing your bulkheads onto the end cap.
Installing a Bulkhead
1. Inspect the bulkhead O-ring to make sure it is not dirty or damaged.
2. Lubricate the bulkhead O-ring with a thin layer of silicone grease and install it in the groove on the underside of the bulkhead.
wte-guide-assembly-8
End cap holes can be either threaded or unthreaded.
wte-guide-assembly-14
Installing in an Unthreaded Hole
1. Insert the bulkhead through the hole and fasten a penetrator nut on the other side. Tighten the nut and bulkhead by hand until the bulkhead is held in place.
wte-guide-assembly-9
2. Use the Bulkhead Wrench to fully tighten the bulkhead. The Bulkhead Wrench can be used to tighten either the bulkhead or the nut. The bulkhead should no longer rotate in the hole when installed properly. If the bulkhead cannot be loosened using your fingers, it is tight enough.
wte-guide-assembly-10
Installing in a Threaded Hole
1. Thread the bulkhead into the threaded hole until it is finger-tight. Do not use a penetrator nut in the back of the bulkhead.
wte-guide-assembly-11
No penetrator nut used.
2. Use the Bulkhead Wrench to fully tighten the bulkhead. If the bulkhead cannot be loosened using your fingers, it is tight enough.
wte-guide-assembly-13
Using Blank Penetrators
After installing all of your bulkheads, seal any unused holes in the end cap with a penetrator blank.
Finishing Assembly
1. Remove the plug from the Pressure Relief Valve or vent.
wte-guide-assembly-15
2. Install the flanges onto the tube. The flanges have a rotation locking tab that must sit in the slot in the tube to fully seat the flange.
Rotation locking tab in slot.
2. Reinstall the Pressure Relief Valve or vent plug back in the bulkhead to seal it.
prv-guide-3
3. Insert the plastic locking cord through the slot and feed it through the locking cord channel. Push it all the way in until it reaches around to the other side.
wte-guide-assembly-5
4. Install the locking cord handle onto the locking cord so it sits close against the tube. Tighten the set screw using a 1.5 mm hex driver.
wte-guide-assembly-6
5. Trim any excess locking cord.
wte-guide-assembly-7
Vacuum Testing an Enclosure
We strongly recommend performing a vacuum test on all newly assembled Watertight Enclosures or whenever you install or remove a bulkhead. Check out the guide below for instructions on how to use the hand-operated vacuum pump kit to test your enclosures.
Opening and Closing an Enclosure
Opening
1. Remove the vent or Pressure Relief Valve plug from the bulkhead.
wte-guide-assembly-16
2. Pull out the locking cord.
wte-guide-assembly-17
3. Remove the flange from the tube.
wte-guide-assembly-18
If removing the flange from the tube is difficult, try pushing the flange up from the end cap tabs. Alternate pushing up from the tab on each side of the end cap until the flange is off.
wte-guide-assembly-19
You can also use the Watertight Enclosure Pry Tool. Insert the pry tool into the locking cord slot or the pry slots then give it a twist to separate the flange from the tube.
pry-tool-using
Closing
1. Make sure the vent or Pressure Relief Valve plug is not installed in the bulkhead.
2. Insert the flange fully into the tube. Make sure the rotation locking tab on the flange sits in the slot in the tube.
3. Insert the locking cord through the slot and push it all the way in to lock the flange to the tube.
4. Reinstall the plug in the bulkhead to seal the enclosure.
Removing a Bulkhead
Use a Bulkhead Wrench to turn the bulkhead or nut counterclockwise until it is loose enough to remove by hand.
Maintenance
  • Check that O-rings are not dirty or damaged after servicing the enclosure. Replacement O-ring sets can be found here.
  • Relubricate the inner edge of the tube and the radial seal O-rings with silicone grease if the flanges become difficult to remove.
  • Relubricate the PRV or vent plug O-rings with silicone grease if it becomes difficult to remove.
  • Only use a microfiber cloth to clean acrylic components to avoid scratching. NEVER use alcohol or other solvents to clean acrylic parts.
Customization
Drilling holes
The acrylic and aluminum end caps can be drilled to make your own custom hole configuration. Use a 10 mm drill bit to make holes for M10 bulkheads or a 14 mm drill bit for M14 bulkheads.
Installing Micro Circular Wet-Mateable Connectors
The standard thread for most Subconn and Seacon type Micro Circular connectors is 7/16″-20. The M10 end cap holes are the ideal size to be tapped with a 7/16″-20 tap to make the proper threads. Before tapping, make sure the end cap you are using is thick enough to make enough threads. For end caps that are too thin, you can just use a 7/16″ drill bit to drill out the hole and install the connector using a nut instead.
Custom End Caps
One of the coolest things about the modular design of the Watertight Enclosures is that it’s compatible with all sort of end cap sizes and shapes. We provide a variety of end cap options but we encourage you to design your own to perfectly suit your application. The 3D files provided on the product page, as well as the DXF files below, will give you a good starting point for your design. You’ll need access to either 3D modeling software like SolidWorks or AutoCAD or 2D drawing software like Adobe Illustrator, Inkscape, and others. Once you have a design, you can cut the parts yourself if you have a laser cutter or use an online service. We have frequently used Pololu Laser Cutting with great results.
The thicknesses and depth ratings for all of our end caps are provided in the technical details section for reference when creating your design. If you need to design for a particular depth rating, we recommend using Under Pressure software.
Under Pressure – Pressure Vessel Calculator
Use the Under Pressure software to calculate theoretical failure depths for various enclosures.
