The Ping360 sonar is a mechanical scanning sonar. You can see echoes from objects like ropes, walls, dock pilings, rocks, shipwrecks, boats, and any other structures or objects that reflect sound waves. With that, you have reference points to navigate from, regardless of water visibility, and you can locate important features in the water quickly.
One of the unique features of the Ping360 is the ability to have user configurable communications interface types by changing a few wires around. This guide will show how to configure a Ping360 for USB, RS-485, or Ethernet communications.
Ping360 is shipped with the USB configuration by default.
If the Ping360 is changed over to Ethernet communications, DO NOT plug it into a computer via the USB connection, it will damage the transformer on the Ethernet configuration.
The M10 Bulkhead Wrench is used in this guide.
Separate the Ping360 Body
To remove the Ping360 body halves, you will need the following tool:
  • 1 x M10 Bulkhead Wrench
1. Remove the plastic cord retaining the two body halves together.
Ping360 Cord
2. Using the M10 Bulkhead Wrench, loosen the penetrator just enough so that the air can be equalized.
Ping360 Wrench
3. Gently slide the two halves apart. Avoid opening the Ping360 with too much force that the wires are ripped out.
Ping360 Open
Ping360 Processor Board Overview
  • The following image shows the different interface port locations:
Ping360 Protocol Port Locations
The LED port is unused.
Processor Board - USB Configuration
  • Move the 4-pin JST-GH plug to the “USB” configuration port.
  • Ensure the plug firmly clicks into the receptacle.
Ping360 USB Configuration
Processor Board - RS-485 Configuration
  • Move the 4-pin JST-GH plug to the “RS485” configuration port.
Ping360 RS485 Configuration
Processor Board - Ethernet Configuration
  • Move the 4-pin JST-GH plug to the “ETHERNET” configuration port.
Ping360-Ethernet-Configuration
Reassemble Ping360
1. Gently slide the upper head assembly onto the base with the penetrator loose so air can escape.
Ping360 Body Alignment
2. Slide the plastic cord in its channel to hold the two halves together.
Ping360 Cord
2. Using the Bulkhead Wrench, tighten the penetrator so it is “hand tight”.
Ping360 Wrench
Wiring Connections - USB Configuration
  • 1 x 4-pin JST-GH to 4-pin JST-GH adapter PCB (included with Ping360)
  • 1 x 4-pin JST-GH to USB-A adapter (included with Ping360)
1. Connect the power wires (red and black wires) into open screw power terminals (11-25VDC).
Ensure the power wires are correctly installed (positive and negative) before the device is powered on. Ping360 does not have any reverse polarity protection and the Processor Board will be damaged if powered incorrectly.
2. Plug the JST-GH to JST-GH inline connection board into JST-GH connector coming from the Ping360.
3. Plug the JST-GH to USB-A cable into the other end of the JST-GH to JST-GH inline connection board.
4. Plug the JST-GH to USB cable (USB side) into a computer.
Ping360 Wiring USB
Wiring Connections - RS-485 Configuration
  • 1 x 4-pin JST-GH to male header pin adapter cable (included with Ping360)
  • 1 x 4-pin JST-GH to female header pin adapter or 2 x 0.1″ male-female jumper wires (not included)
3. Plug the 4-pin JST-GH to male header pin adapter into the JST-GH to JST-GH inline connection board.
4. Plug the male header pin adapter into an unused twisted wire pair on the tether.
5. Plug a 4-pin JST-GH to female header pin adapter or 2x 0.1″ male-female jumper wires into the corresponding unused twisted wire pair coming from the FXTI tether pigtail.
6. Plug a 4-pin JST-GH to female header pin adapter or 2x 0.1″ male-female jumper wires into the RS-485 TX/RX pins on the RS485 side of the BLUART.
7. Plug the BLUART into a computer using a Micro-USB to USB-A cable.
Ping360 Wiring RS485
Wiring Connections - Ethernet Configuration
  • 1 x Ethernet Cable (not included)
2. Plug the JST-GH connector coming from the Ping360 into the JST-GH connector on the RJ45 to JST-GH Adapter Board.
3. Plug an Ethernet cable into the RJ45 jack on the RJ45 to JST-GH Adapter Board.
4. Connect the other end of the Ethernet cable to a router or your computer.
For integration in a vehicle (using an Ethernet Switch) please see the ethernet wiring section of the installation guide.
Ping360-Wiring-Ethernet
Configure Network Settings
1. Make sure you are using Ping Viewer version 2.4.1 or newer. Configure the Ping360 Network settings from the Ping Viewer device manager screen.
  • The Ping360 is configured as a DHCP client by default and will be assigned an IP address automatically when connected to a DHCP server such as a router.
  • The IP address can also be configured manually by opening the network configuration menu and selecting “Static IP”. Enter an IP address that is on the same subnet as the computer you are trying to connect from.
  • The Ping360 must be configured with an IP address that is on the same subnet as the topside computer in order for Ping Viewer to be able to connect to it.
    Example: If your topside computer’s IP address is 192.168.2.1 with a subnet mask of 255.255.255.0, the IP address used for the Ping360 should be 192.168.2.X (e.g. 192.168.2.4).
ping360-setup-1-1
ping360-setup-3
USB Configuration
1. Ensure the power and data wires are correctly plugged into their respective ports (POWER, USB) on the Ping360 processor board.
2. Ensure the power wires are correctly installed (positive and negative) into the power source. Ping360 does not have any reverse polarity protection and the Processor Board will be damaged if powered incorrectly.
3. Ensure the JST-GH connectors are plugged firmly into their receptacles. There will be a mechanical “click”.
4. Check to make sure you have the most recent stable release of Ping Viewer.
5. Contact [email protected] for further troubleshooting recommendations.
RS485 Configuration
1. Ensure the power and data wires are correctly plugged into their respective ports (POWER, RS485) on the Ping360 processor board.
4. Try reversing one of the header pin connectors.
5. Check to make sure you have the most recent stable release of Ping Viewer.
6. Contact [email protected] for further troubleshooting recommendations.
1. Ensure the power and data wires are correctly plugged into their respective ports (POWER, ETHERNET) on the Ping360 processor board.
5. Check to make sure the Ping360 network settings have been configured correctly in Ping Viewer.
6. If you have a firewall enabled, create an exception rule to allow Ping Viewer through the firewall.
7. Contact [email protected] for further troubleshooting recommendations.
