$1,850.00
Sense wind speed and direction, air temperature, barometric pressure, and GPS position with this rugged WeatherStation that’s built to withstand the harsh marine environment.
SKU: BR-106326 Categories: , ,
HS Code: 9015.80
Country of Origin: USA
We love a nontraditional take on an old-school product. Meet the Airmar 300WX-IP67 WeatherStation, the perfect addition for your surveying system setup.
Most wind sensors have moving parts, may not fare well in a marine environment, and measure only wind speed and direction. They often communicate with proprietary methods to dedicated receivers or vendor software.
The Airmar 300WX-IP67 WeatherStation switches things up by combining GNSS positioning, a stabilized 3-axis compass, and ultrasonic wind sensing, so it can subtract out the platform’s changing heading and report true wind direction, even while on the move.
Mount it to a BlueBoat, a buoy, or any other autonomous surface platform, and obtain data directly from the cable in the BlueOS extension or via the Airmar CAST app via Bluetooth.
It Doesn't Have to Be Complicated
The wind measurement is ultrasonic, so there are no cups to spin, no vanes to seize up, nothing to replace after a season of use. Combined with an IP67-rated housing, the WeatherStation is built for the kind of unattended, exposed environment that offshore platforms, buoys, commercial workboats, and uncrewed surface vehicles actually need.
And it’s more than just wind! Along with wind speed and direction, the WeatherStation also reports air temperature, barometric pressure, GNSS position, and the pitch, roll, and rate-of-turn of whatever it’s mounted to. Together, this gives you a full picture of the conditions wherever it’s mounted.
On the BlueBoat, the WeatherStation mounts straight onto the BlueBoat Antenna and Accessory Mast, no extra hardware required. A WetLink Penetrator on the end of the 3 m cable makes connecting to any system quick and easy.
  • 1 x 300WX WeatherStation
  • 1 x 300WX 3 m Cable
  • 1 x USB-RS232 Adapter
  • 1 x 300WX Mast Adapter (BR-103613)
  • 3 x Inline Snap Connectors
  • 1 x M10 Nut
  • 1 x O-Ring
Electrical
Supply Voltage9–40 V
Supply Current @ 12 V<55 mA (<0.66 W)
Cable Length3 m
Performance
Wind Speed
Range0–40 m/s
Accuracy1.5 knots RMS @ 20 knots
Resolution0.1 m/s
Wind Direction
Range0–359.9°
Accuracy2.5° RMS @ 20 knots
Resolution0.1°
Air Temperature
Range-25 to 55°C
Accuracy± 1.1°C @ 20°C
Relative Humidity
Range0–100% RH
Accuracy± 5% RH @ 0–90% RH, 20°C
Barometric Pressure
Range700–1100 hPa
Accuracy± 1 hPa @ 25°C
3-Axis Compass
Range0–359.9°
Accuracy1° static
2° dynamic
Pitch and Roll
Sensor TypeMEMS
Range±45°
Accuracy± 1° within ±30°
GNSS
Position Accuracy ¹2.5 m CEP
ConstellationsGPS
GLONASS
Galileo
BeiDou
QZSS
Communication
InterfacesRS232
CAN
ProtocolsNMEA 0183
NMEA 2000
J1939
ISOBUS
CAN Baud Rate250 or 500 kbps (auto-detected)
Computer ConnectionUSB, via the included USB to RS232 adapter
ConfigurationBluetooth, with the Airmar CAST app
Cable
Cable Length3 m
WetLink Penetrator SizeM10-6.5mm-HC
Penetrator O-ringAS568-013 Buna-N 70A
Physical
Dimensions (D x H)72 x 131 mm
Weight300 g
Mounting Thread1″-14 UNS
Certifications
Weatherproof RatingIP67 (300WX-IP67)
StandardsCE
RoHS
IEC 61000-4-2
IEC 60945
IEC 60950
EN 55022
EN 55024
EN 14982
All specifications are available on the Airmar site.
Airmar 300WX IP67 WeatherStation
Airmar 300WX IP67 WeatherStation Drawing
300WX_public (.zip)
3 November 2026
  • BR-106326 – Initial release
Installing the Airmar 300WX-IP67 WeatherStation on the BlueBoat Antenna and Accessory Mast
The BlueBoat Antenna and Accessory Mast raises the height of the antenna to improve line of sight and increase range...
