Price range: $6.00 through $16.00 / meter
These cables are built specifically for use underwater and used in our products! A polyurethane jacket and flexible conductors make for a rugged cable. Sold by the meter (3.3 ft) and cut to length when you order.
We are currently experiencing supplier issues and do not have a back in stock date for the Lumen/Gripper Cable (BR-101050) at this time.
Product Price
U.S. customers will be charged a tariff surcharge of $0.72 - $1.92 for this product. Learn more
SKU: CAB-PUR-VP
HS Code: 8544.11.0050
These cables are built for a wide range of subsea applications, custom made with a pressure-extruded polyurethane jacket and flexible conductors. They are very tough and abrasion resistant.
These cables are used in the the Newton Gripper, the Ping Echosounder, the Lumen Lights, and in countless other applications!
  • 1x Selected cable with bare ends, cut to length
CableLumen/Gripper CablePing CableEthernet and Power Cable
Construction3-conductors, jacket4-conductors, powder separator, jacket2-conductor 22 AWG, 4-unshielded twisted pairs 26 AWG, filler, wrap, jacket
Diameter4.5 mm4.5 mm7.5 mm
Outer JacketPressure-extruded polyurethanePressure-extruded polyurethanePressure-extruded polyurethane
Wrap--2-layer non-woven wrap
Filler--String
Number of Conductors342 x 22 AWG
8 x 26 AWG
Conductor Gauge22 AWG24 AWG22 AWG
26 AWG (UTP)
Conductor InsulationPolypropylenePolypropylenePolypropylene (22 AWG)
FEP (UTP)
Conductor Insulation ColorsBlack, red, yellowBlack, white, green, redBlack
Red
Blue, blue/white
Brown, brown/white
Green, green/white
Orange, orange/white
Static Minimum Bend Radius15 mm15 mm24 mm
Compatible WetLink PenetratorM06-4.5mm-LC
M10-4.5mm-LC
M06-4.5mm-LC
M10-4.5mm-LC
M10-7.5mm-LC
18 July 2023
  • CAB-PUR-2-22AWG-4UTP-26AWG-R1 SKU changed to BR-100897
  • CAB-A-3-22AWG-R1 SKU changed to BR-101050
6 April 2023
  • CAB-PUR-4-24AWG-R1 SKU changed to BR-100452
8 February 2022
  • CAB-PUR-2-22AWG-4UTP-26AWG-R1 – Initial release
29 January 2019
  • Changed construction to remove Teflon tape
  • Increased jacket diameter
  • Changed to polypropylene insulation
11 January 2017
  • CAB-PUR-4-24AWG-R1 – Initial release
24 February 2016
  • CAB-A-3-22AWG-R1 – Initial Release
Cable Stripping
Learn how to properly strip cables for use with WetLink Penetrators!
WetLink Penetrator Assembly and Installation
This guide will show you how to assemble and install a WetLink Penetrator.
Potting a Cable Penetrator
Learn to pot the perfect penetrator to pass a cable into your watertight enclosure!
Community
Blue Robotics Forum
