Ping Installation Guide for the BlueROV2
The Ping sonar is a multipurpose single-beam echosounder with a 100 meter sonar range and 300 meter depth rating. When mounted on a BlueROV2, the Ping can be used as an altimeter to measure how high the BlueROV2 is above the seafloor.
The Ping2 can be connected directly to the Navigator Flight Controller serial ports. If you are installing the Ping on an older ROV equipped with a Pixhawk autopilot, you will need to connect the Ping using the BLUART USB to TTL Serial Adapter and a micro-USB cable:
To complete the installation, you will also need the following tools (not included):
- 1 x M10 Bulkhead Wrench
- 1 x 2 mm hex driver
- 1 x 3 mm hex driver
- 1 x #2 Phillips screwdriver
- 1 x Power drill and a 5.50 mm (or 7/32”) drill bit
- Medium-strength threadlocker such as Loctite 242 or 243
- Zip ties for cable management
- 1 x Sharpie or other type of marking pen
Preparing the BlueROV2
In order to install the Ping, it is necessary to open up the BlueROV2 Electronics Enclosure and remove one of the penetrators. To do this you will need:
If you are not sure how to perform any of the steps in this section, more detailed instructions for each operation are available in the ‘Servicing the BlueROV2’ section of the BlueROV2 Operation guide.
Installing the Penetrator
To install Ping’s penetrator into the end cap, you will need the following parts and tools:
- 1 x Ping sonar
- 1 x Penetrator Nut (included with the Ping)
- 1 x Penetrator O-ring (included with the Ping)
- 1 x Silicone Grease (Molykote 111)
1. Your Ping may have the JST GH cable adapter already connected to the end of the cable, disconnect this adapter before moving on to the next steps.
2. Wipe the exterior surface of the end cap around the penetrator hole you previously removed the blank penetrator from. Ensure the area around the hole where the O-ring will sit is free of dust or debris.
3. Inspect the penetrator O-ring to make sure it is not dirty or damaged.
4. Lubricate the O-ring with a thin layer of silicone grease and install it in the groove on the underside of the penetrator.
5. Install the penetrator in the hole and fasten the penetrator nut on the other side. Tighten the nut and bulkhead by hand until finger-tight. Use the Bulkhead Wrench to fully tighten the penetrator. The penetrator should no longer rotate in the hole and you should not be able to loosen it using your fingers when installed properly.
The connection of the Ping wires inside the ROV depends on whether your BlueROV2 is equipped with a Navigator Flight Controller or a Pixhawk Autopilot. If your BlueROV2 has a Navigator, follow the instructions under ‘Installation with a Navigator’. If your BlueROV2 has a Pixhawk, follow the instructions under ‘Installation with a Pixhawk’.
For this step you will need:
- 1 x Header pin to JST GH Cable Adapter (included with Ping)
1. Plug the male header pins from the Ping cable into the female 4-position header from the JST GH cable adapter, matching the wire colors as you do so (red to red, black to black, white to white, green to green).
2. Plug the 6-position JST GH connector into the ‘SERIAL 5 + I2C 6′ port on the Navigator.
- 1 x BLUART USB to TTL Serial Adapter (not included)
- 1 x micro-USB to USB-A cable (not included)
2. Plug the 6-position JST GH connector into the 6-position serial port on the BLUART adapter.
3. Connect a micro-USB cable to the BLUART then plug the USB-A side of the cable into a USB port on the Raspberry Pi.
Reassemble the Electronics Enclosure
To reassemble the Electronics Enclosure, you will need:
- The M3 mounting screws you removed previously
1. Apply a thin coat of silicone grease to the two radial O-rings on the O-ring flange and the inner end of the tube.
2. Reinstall the tube and dome assembly onto the flange. If the ROV has a locking-style enclosure, ensure the rotation locking tab sits inside the slot in the tube.
3. Insert the locking cord through the slot. Older ROVs may not have a locking cord.
4. Reinstall the PRV or vent plug back in the bulkhead. Turn the plug clockwise until it stops to seal it.
5. Place the Electronics Enclosure on the enclosure cradles and line up the mounting clips with the screw holes on the cradles. Use the 2.5 mm hex to install the screws through the mounting clips and into the front and rear enclosure cradles
Mounting the Ping to the BlueROV2 Frame
To mount the Ping to the BlueROV2 frame, you will need:
- 1 x Ping mounting bracket (included with Ping)
- 4 x M3x5 button head cap screws (included with Ping)
- 2 x M5x16 button head cap screws (included with Ping)
- 1 x Bottle of threadlocker
- 1 x Marking pen
1. Use the four M3x5 button head cap screws and the 2 mm hex driver to secure the Ping to the mounting bracket.
2. There is no template for where the Ping must be mounted on the frame, the final placement is up to the user. The Ping should be mounted on top of the BlueROV2 bottom frame panel with the face of the transducer facing down. Find a location where it will not contact the battery enclosure and the transducer is not obstructed.
3. After you have decided on a location to mount the Ping, flip the ROV upside down and use the mounting bracket as a template to mark the placement of the two M5 holes using the marker.
4. Use the power drill to drill mounting holes straight through the bottom frame panel.
5. Coming from the rear of the BlueROV2, route the Ping assembly through the frame to its mounting location. Apply a drop of threadlocker to the bottom of the M5x16 screws. Use the 3 mm hex driver and the M5x16 screws to secure the mounting bracket to the frame. The screws should go through the bottom panel and screw into the mounting bracket on the other side.
The goal of good cable management is to secure the cable to the ROV frame to prevent it from getting damaged by the thruster propellers or getting caught on something during operation. Secure the cable to the frame using zip ties so there are no loose cable and make sure to check that the cable cannot reach a thruster propeller after you have finished.
The Ping adds some weight to the BlueROV2 frame so the ROV ballast will need to adjusted to keep it neutrally buoyant and balanced in the water. Add, remove, or relocate the ballast weights on the bottom of the frame to adjust the ballast. You can view complete instructions for adjusting the ballast in the ‘Servicing the BlueROV2’ section of the BlueROV2 Operation guide.
1. Follow the Ping Viewer Quick Start to install the latest version of Ping Viewer.
2. Power on your BlueROV2 and connect it to your computer.
3. Start Ping Viewer, it should automatically detect the connected Ping sonar and display it in the device manager menu.
4. Select the Ping from the device manager menu and the waterfall display should automatically start.
Review the complete Ping Viewer documentation to learn about the available Ping device settings and other features.
Other Guides
Ping Echosounder Sonar User Manual
Using the Ping Sonar with an Arduino
