$12.00
This vent allows trapped pressure to escape from an enclosure after it has been closed. It includes a threaded plug with a double O-ring seal to open and close the vent.
U.S. customers will be charged a tariff surcharge of $1.44 for this product. Learn more
SKU: BR-100783 Category:
HS Code: 7616.10.7090
Country of Origin: China
When the end caps and flanges are installed on our watertight enclosures, the air inside is compressed a bit and tries to push the enclosure open. This vent allows you to quickly and easily release the pressure and then seal things back up. You can also use it to vacuum-check your enclosure, ensuring there’s no leaks. It’s based on our standard M10 threaded bulkhead design with an added “plug” that fits in to seal it. The plug is sealed with double O-rings and screws into the bulkhead.
Features
  • Anodized aluminum construction for corrosion resistance and high strength
  • O-ring seal that works on any smooth surface
  • Threaded plug can be tightly secured
Features
  • 1 x Vent Bulkhead
  • 1 x Vent Plug
  • 1 x M10 Nut
  • 1 x O-ring for Bulkhead
  • 2 x O-ring for Vent Plug
Performance
Maximum Rated Depth (seawater)1000 m3280 ft
Design Lifetime¹3 years or 500 cycles to rated depth
Temperature Rating-40 to 60°C-40 to 140°F
Tools
Compatible Bulkhead WrenchBR-100977-010
Recommended Installation Torque3.5 N⋅m
Physical
Recommended Through Hole Diameter10.2 mm
Bulkhead ThreadM10 x 1.5
Bulkhead Thread Length20 mm
Bulkhead/Nut Wrench Flats16 mm
Overall Assembled Height From Endcap25 mm
Overall Outer Diameter18 mm
Bulkhead O-ring SizeAS568-013 Buna-N 70A
Plug O-ring Size1.5 x 11.5 mm Buna-N 70A
Bulkhead/ Plug Material7075-T6 Anodized Aluminum
Wetted MaterialsBuna-N Rubber
Molykote 111 Compound
In Air Weight (No Nut)14.3 g
In Water Weight (No Nut)8.5 g
¹ Design life was used to inform testing in an accelerated environment, does not reflect warranty period.
 Drawing
VENT-M10-R1 (.zip)
VENT-M10-PLUG-R1 (.zip)
14 July 2023
  • VENT-M10-R1-RP SKU changed to BR-100783
14 February 2023
  • Bulkhead O-ring color changed to blue
23 February 2022
  • VENT-M10-R1 - Initial release
  • Redesigned Vent Plug and Vent Bulkhead for product compatibility
31 March 2015
  • R1 - Initial release
WTE Vent Assembly Guide
Quickly assemble a vent for your WTE project!
6″ and 8″ Series Non-Locking Watertight Enclosure (WTE) Assembly
Learn the basics of assembling a Non-Locking Watertight Enclosure (WTE)!
Community
