Optically clear, cast acrylic tube for use with the original Watertight Enclosure for ROV/AUV (4″ Series).
Cast Acrylic Tube – 11.75″, 298mm (4″ Series)
$90.00
This optically clear, cast acrylic tube for use with the 4″ Series Watertight Enclosure.
Out of stock
- 1 x 4″ Series Cast Acrylic Tube (11.75″, 298mm)
Parameter | Value | |
Material | Cast Acrylic | |
Surface Finish | Optically Clear | |
Weight in Air | 768 g | 1.69 lb |
Depth Rating | 100 m | 328 ft |
![](https://bluerobotics.com/wp-content/uploads/2018/10/WTE4-P-TUBE-12-R2-2D-DRAWING.png)
WTE4-ASM-R2 (.zip)
9 July 2015
- R1 – Initial Release
![](https://bluerobotics.com/wp-content/uploads/2019/01/4-step-3-300x300.png)
Learn the basics of assembling a Watertight Enclosure (WTE)!
![](https://bluerobotics.com/wp-content/uploads/2015/11/vacuum-plug-switch-update-10-300x300.jpg)
