$90.00
This optically clear, cast acrylic tube for use with the 4″ Series Watertight Enclosure.
Out of stock
SKU: WTE4-P-TUBE-12-R1-RP
HS Code: 3917.32.0050
Optically clear, cast acrylic tube for use with the original Watertight Enclosure for ROV/AUV (4″ Series).
  • 1 x 4″ Series Cast Acrylic Tube (11.75″, 298mm)
MaterialCast Acrylic
Surface FinishOptically Clear
Weight in Air768 g 1.69 lb
Depth Rating 100 m 328 ft
WTE4-ASM-R2 (.zip)
9 July 2015
  • R1 – Initial Release
Learn the basics of assembling a Watertight Enclosure (WTE)!
Support Community
You May Also Need
Related Products
