Aluminum End Cap with 2 Holes (2″ Series)
$10.00
This aluminum end cap with 2 holes is for use on the 2″ Series Watertight Enclosure.
Out of stock
This aluminum end cap with 2 x 10mm holes for use with Watertight Enclosure for ROV/AUV (2″ Series). If you’re looking for a complete set of parts for an enclosure, we highly recommend using the enclosure configurator here.Product Description
This aluminum end cap with 2 x 10mm holes for use with Watertight Enclosure for ROV/AUV (2″ Series). If you’re looking for a complete set of parts for an enclosure, we highly recommend using the enclosure configurator here.Contents
- 1 x Aluminum End Cap with 2 x 10mm holes
- 6 x M2x10 screws
Parameter | Value | |
Material | 6061 or 6063 Aluminum | |
Surface Finish | Type 2 Hard Anodizing | |
Weight in Air | 41 g | 0.09 lb |
Depth Rating | 1000 m | 3280 ft |
![](https://bluerobotics.com/wp-content/uploads/2016/12/WTE2-P-END-CAP-2-2X10MM-R1.png)
WTE2-M-END-CAP-2-HOLE-R1 (.zip)
28 December 2016
- R1 – Initial release
![](https://bluerobotics.com/wp-content/uploads/2019/01/4-step-3-300x300.png)
Learn the basics of assembling a Watertight Enclosure (WTE)!
![](https://bluerobotics.com/wp-content/uploads/2015/11/vacuum-plug-switch-update-10-300x300.jpg)
