Price range: $34.00 through $166.00
The Enclosure Clamps are available for all diameters of Watertight Enclosure for easy mounting on a vehicle. They can be attached to each other to create unique enclosure configurations.
U.S. customers will be charged a tariff surcharge of $4.08 - $19.92 for this product. Learn more
SKU: WTE-CLAMP-VP Categories: ,
HS Code: 7616.99.5190
Country of Origin: China
These anodized aluminum clamps for cylindrical Watertight Enclosures provide a simple and easy mounting solution. The threaded mounting holes allow the watertight enclosure to be mounted flush to the structure of your vehicle or on a Payload Skid for the BlueROV2.
The unique mounting hole pattern allows any clamp to attach to any other clamp, opening up all sorts of possibilities for custom enclosure configurations.
CAD models are of the 2″, 4″, and 6″ clamps.
2″ Clamps
  • 2 x Clamp halves
  • 1 x Adhesive rubber strip (BR-100043)
  • 2 x M3 Hex nut (BR-100371)
  • 2 x M3x8 Socket head cap screw (BR-100989)
  • 4 x M4x8 Socket head cap screw (BR-102694)
  • 2 x M4x14 Socket head cap screw (BR-100334)
3″ and 4″ Clamps
  • 2 x Clamp halves
  • 2 x Adhesive rubber strip (BR-100043)
5″, 6″ and 8″ Clamps
  • 2 x Clamp halves
  • 2 x Adhesive rubber strip (BR-102699)
  • 4 x M6x12 Socket head cap screw (BR-102692)
  • 8 x M6x20 Socket head cap screw (BR-102241)
 Drawing
Series DiameterMaterialsLength (A)Height (B)Length (C)Radius (D)Width (E)Clamping Screw Holes (F)Mounting Screw Holes (G)Weight ¹Part Number
50 mm (2")Aluminum 6061-T6, type III anodized
Buna-N 50A
Stainles steel 316
87.2 mm35.9 mm27 mm30.85 mm17.0 mmM4x0.72x M4x0.754 gBR-102710-002
75 mm (3")119.4 mm50.0 mm47 mm46.05 mm30.0 mm4x M4x0.7161 gBR-102710-003
100 mm (4")144.9 mm62.8 mm47 mm58.75 mm30.0 mm192 gBR-102710-004
130 mm (5")177.8 mm78.1 mm80 mm71.35 mm53.0 mmM6x1.04x M6x1.0599 gBR-102710-005
150 mm (6")203.1 mm90.6 mm80 mm83.95 mm53.0 mm645 gBR-102710-006
200 mm (8")255.6 mm116.1 mm80 mm109.1 mm53.0 mm822 gBR-102710-008
¹ In air weight of two clamps, rubber strips, and clamping hardware.
Mounting Patterns
WTE2_CLAMP_BR-102710-002 (.zip)
WTE3_CLAMP_BR-102710-003 (.zip)
WTE4_CLAMP_BR-102710-004 (.zip)
WTE5_CLAMP_BR-102710-005 (.zip)
WTE6_CLAMP_BR-102710-006 (.zip)
WTE8_CLAMP_BR-102710-008 (.zip)
6 August 2024
  • BR-102710-002, 2" Watertight Enclosure Clamp - Initial release
  • BR-102710-003, 3" Watertight Enclosure Clamp - Initial release
  • BR-102710-004, 4" Watertight Enclosure Clamp - Initial release
  • BR-102710-005, 5" Watertight Enclosure Clamp - Initial release
  • BR-102710-006, 6" Watertight Enclosure Clamp - Initial release
  • BR-102710-008, 8" Watertight Enclosure Clamp - Initial release
5 December 2023
  • BR-102474, WTE2 Clamp Packed Assembly - Initial release
14 June 2023
  • WTE4-M-CLAMP-R1-RP SKU changed to BR-100888
8 June 2023
  • WTE3-M-CLAMP-R1-RP SKU changed to BR-100264
26 November 2019
  • WTE3-M-CLAMP-R1
  • WTE4-M-CLAMP-R1
  • Added 2x 3.18 mm adhesive rubber strips for aluminum tubes with smaller OD
7 November 2016
  • WTE3-M-CLAMP-R1 - Initial release
  • WTE4-M-CLAMP-R1 - Initial release
Watertight Enclosure Clamps Guide
Learn how to install the Watertight Enclosure Clamps!
Forums
You May Also Need
