Price range: $3,475.00 through $3,575.00
This tether reel is designed for the Outland Technology Power Supply (OTPS) high-power tether. It keeps the tether organized and tangle-free inside an SKB hard case with built-in pull handle and wheels for convenient transport and storage. The removable crank handle and slip ring make tether deployment and retrieval easy.
It’s available in two models: the RL-500 for 125 meter OTPS tether and the RL-750 for 250 meter OTPS tether. Tether not included!
SKU: OTPS-REEL-VP Categories: ,
HS Code: 8479.89
Country of Origin: USA
Keep your Outland Technology Power Supply high-power tether protected and tangle-free with the RL-500 and RL-750 tether reels. Designed specifically for the Outland Technology Power Supply system, each reel features a waterproof, high-power slip ring rated to handle the high voltages used by the OTPS system.
The reels are built into SKB iSeries hard cases with an integrated pull handle and wheels for easy transport. An integrated extension cable with a Binder 696 connector is pre-installed and ready to connect directly to the OTPS topside unit for quick setup. A removable crank handle is used for manual operation and stows inside the case for storage. The reels are compact and portable, but can hold a lot of tether:
  • RL-500 stores up to 150 m of OTPS tether
  • RL-750 stores up to 360 m of OTPS tether
These reels are available individually on this page or as part of a complete topside power system configured through the Outland Technology Power Supply product page.
These reels are not compatible with Blue Robotics Fathom ROV-Ready Tether.
Tether sold separately.
  • 1 x High-power OTPS tether reel with integrated extension cable
  • 1 x Removable crank handle
ModelRL-500RL-750
Physical
External ConnectorBinder 696 male
Internal ConnectorBinder 696 female
Extension Cable Length6 m
Maximum OTPS Tether Capacity ¹150 m360 m
External CaseSKB iSeries 2015-14SKB iSeries 2418-16
Dimensions (LxWxH)586 x 458 x 395 mm675 x 522 x 448 mm
Height Open783 mm910 mm
Weight (without tether)13.6 kg (30 lbs)16.3 kg (36 lbs)
Internal Reel Dimensions
Traverse Length416 mm503 mm
Fill Diameter336 mm387 mm
Barrel Diameter216 mm216 mm
¹ OTPS tether available in 125 m and 250 m lengths only.
 Drawing
OUTLAND_TECHNOLOGY_RL-500_BR-105531 (.zip)
OUTLAND_TECHNOLOGY_RL-750_BR-106182 (.zip)
10 February 2026
  • BR-105531, RL-500 – Initial release
  • BR-106182, RL-750 – Initial release
Quick Start
To load the OTPS tether on the reel:
1. Connect the tether to the internal connector in the center of the spool.
2. Starting on the right side of the spool, crank the handle away from you to wind the tether onto the spool. Maintain light, consistent tension on the tether as it is wound.
3. Guide the tether onto the spool by hand to form tight, even loops. Wind one complete layer at a time and do not crossover between wraps.
Outland Technology Power Supply BlueROV2 Integration
Convert your BlueROV2 to use a topside power supply instead of batteries.
