$325.00
Keep an eye on what’s going on behind, above, or below your vehicle with the DWE exploreHD camera. This USB camera adds an extra live view to your BlueROV2, BlueBoat, or other vehicle with simple plug-and-play installation. It delivers 1080p video with onboard processing for clear underwater visibility, accurate color, and automatic white balance.
A preinstalled WetLink Penetrator and USB connector make installation easy. Depth-rated to 400 meters and includes an adjustable bracket for mounting at various angles and locations. Vehicle mounting hardware not included!
53 in stock
SKU: BR-103870 Categories: , , ,
HS Code: 8525.89
Country of Origin: USA
The DeepWater Exploration exploreHD is a 400-meter depth-rated USB camera that easily connects to your BlueROV2, BlueBoat, or other vehicle to provide an additional live video stream.
It plugs directly into the onboard Raspberry Pi where BlueOS automatically handles camera detection and stream setup. Even if you’re not using BlueOS, this camera is UVC compliant, making it plug-and-play with most host devices.
The camera uses a 1/2.9″ Sony Exmor CMOS sensor for high-quality images and low-light sensitivity. Onboard compression supports H.264, MJPEG, and YUY2 formats without major quality loss or latency. Built-in image processing delivers clear underwater visuals with reliable white balance and color accuracy.
Picture-in-picture shows downward facing DWE exploreHD in Cockpit.
Mount Anywhere, See Everywhere
The exploreHD is ultra compact and can be mounted just about anywhere on a vehicle. Use multiple cameras to get views from any angle—mount one on the bottom of a BlueBoat to observe the seafloor during surveys, keep an eye on your tether with a rear facing camera on your BlueROV2, or use side and top angles for better situational awareness. Streams can be viewed directly in QGroundControl or Cockpit, with support for picture-in-picture in Cockpit to monitor multiple feeds at once.
The camera has a 1-meter cable and preinstalled WetLink Penetrator so it’s ready to connect to either the BlueROV2 or BlueBoat out of the box. It’s enclosed in its own aluminum 6061 housing that is waterproof and rated to 400 meters depth. The included mounting bracket allows the camera to be adjusted to any angle. Hardware to mount the bracket to the vehicle is not included but check out the installation guides for mounting tips and suggestions!
  • 1 x DWE exploreHD USB Camera
  • 1 x Camera mounting bracket
  • 1 x JST to USB-A adapter
  • 2 x M2x6 Phillips head screw
  • 2 x M2 plastic washer
  • 1 x M10 bulkhead nut & -013 O-ring (BR-100167-010)
Sensor
Image Sensor1/2.9” Sony Exmor™ CMOS
Sensor ColorRGB
Sensor TypeRolling shutter
Max Resolution1920x1080
Max Framerate30fps with H.264/MJPEG
Color Channels3
Bits Per Channel8 bits
Compression FormatsH.264, MJPEG, YUY2
Lens
TypeFisheye
Focal Length2.65mm
Lens Aperturef/1.9
Minimum Focus Distance20–30cm
Horizontal FOV (In Air)138°
Vertical FOV (In Air)70°
Diagonal FOV (In Air)168°
Horizontal FOV (In Water)~82°
Electrical
Operating Voltage5V
Operating CurrentMJPEG: 180 mA
H.264: 250 mA
Maximum CurrentMJPEG: 200 mA
H.264: 260 mA
Operating WattageMJPEG: 0.9 W
H.264: 1.2 W
Minimum Wattage0.004 W
Maximum WattageMJPEG: 1 W
H.264: 1.3 W
Cable
Cable Length1 m external
250 mm internal
WetLink Penetrator Size
DeviceM06-4.5MM-LC
Cable EndM10-4.5MM-LC
Physical
Depth Rating400 m
Overall Outer Diameter39 mm
Wetted MaterialsAluminum 6061-T6, anodized
Aluminum 7075-T6, anodized
Glass
Polyurethane
Buna-N rubber
Molykote 111 compound
In Air Weight (no nut/bracket)84 g
In Water Weight (no nut/bracket)44 g
exploreHD Camera
exploreHD Camera Drawing
Mounting Bracket
Mounting Bracket Drawing
DWE_EXPLOREHD_BR-103870 (.zip)
25 June 2025
  • BR-103870 – Initial release
Installing the DWE exploreHD on the BlueROV2
Learn how to install the DWE exploreHD USB Camera on the BlueROV2!
Installing the DWE exploreHD on the BlueBoat
Learn how to install the DWE exploreHD USB Camera on the BlueBoat!
