This is a replacement bulkhead for the old version of the Vent Plug.
Vent Bolt
$2.00
This is the bulkhead for the old version of the Vent Plug.
This bulkhead is not compatible with the current version of the M10 Enclosure Vent and Plug (black bulkhead).
- 1 x Vent bulkhead
These are the specifications for the complete Vent product.
| Parameter | Value | |
| Recommended Through-Hole Diameter | 10 mm | |
| Bolt Threading | M10 x 1.5 | |
| Bolt Length | 25 mm | 0.98 in |
| Bolt Head / Nut Diameter | 18 mm | 0.71 in |
| Wrench Flats | 16 mm | 5/8 in |
| Bolt O-ring | AS568-013 Buna-N 70A | |
| Plug O-rings | 2mm Wide, 6mm ID, Buna-N | |
| Maximum Tested Depth | 1000 m | 3280 ft |
VENT-M-PLUG-10-A-R3 (.zip)
6″ and 8″ Series Non-Locking Watertight Enclosure (WTE) Assembly
Learn the basics of assembling a Non-Locking Watertight Enclosure (WTE)!
WTE Vent Assembly Guide
Quickly assemble a vent for your WTE project!
