This dispenser makes it easy to dispense compounds in two part cartridges with a mixing nozzle. It can be used with both 1:1 and 2:1 ratio two part cartridges. Requires mixing tips and we recommend surface preparation with acetone wipes.
Potting Cartridge Dispenser
$24.00
This dispenser makes it easy to dispense two part cartridges with a mixing nozzle. Requires mixing tips.
- 1 x Potting Cartridge Dispenser
Parameter | Value |
Plunger Mixing Ratio | 2:1 or 1:1 |
20 September 2018
- R2 – Initial Release
Quick Start
Install the plunger by pushing it through the front of the dispenser with the metal locking tab pulled back. Flip up the retaining clip, and install your 2:1 or 1:1 50 ml two part cartridge, making sure to orient it so the barrels match the plunger ends. Flip down the retaining tab to secure, and squeeze the handle to dispense.
![](https://bluerobotics.com/wp-content/uploads/2019/01/head_filling-300x300.jpg)
Potting a Cable Penetrator
Learn to pot the perfect penetrator to pass a cable into your watertight enclosure!
