This configurable watertight container is great for use on ROVs, AUVs, and other marine robotics applications. Modular end-caps give you options – flat end-cap and end-caps with holes for cable penetrators.
For custom lengths, check out eplastics.com!
SKU: WTE6-ASM-R1-VP
HS Code: 4009.12.00
This modular watertight container is perfect for use on ROVs, AUVs, and other marine vehicles. This enclosure is part of the 6″ Series and has a 6″ inner diameter. A variety of options ensures the right enclosure for your needs.
Features
  • Interchangeable end caps
  • Double O-ring sealed flanges
  • Cast acrylic tube tested to 65m depths
  • Inner mounting holes on CNC aluminum flange
  • Compatible with our cable penetrators
Diagram of the watertight enclosure components.
Features
CAD model demonstrates one possible configuration.
All technical details can be found on the individual component product pages.
27 April 2017
  • R1 – Initial release
6″ and 8″ Series Non-Locking Watertight Enclosure (WTE) Assembly
Learn the basics of assembling a Non-Locking Watertight Enclosure (WTE)!
Community
The standard thread for most Subconn and Seacon type “MCIL” connectors is 7/16"-20. The 10mm holes in the end-cap are the perfect size to be tapped for that threading. A tap like this one can be used to make the proper threads. Depending on the endcap, some holes are spaced closer together, preventing the installation of two connectors immediately adjacent.
Domes are unavailable in this size; only acrylic or aluminum end caps are available.
Electronics trays are currently only available in the 4-inch size.
We do not customize any watertight enclosures.
