Water Linked BlueROV2 Integration (Retired 07 June 2019)
The Water Linked Underwater GPS provides global position of an underwater locator device using acoustic positioning and traditional GPS. On the BlueROV2 or other underwater vehicles it is a huge asset that allows position tracking for navigation, inspection, and mapping.
The Water Linked Underwater GPS is designed with a generic connection interface so that it can be used in a wide variety of applications, but in its stock configuration, it can be difficult to integrate with the BlueROV2. The Water Linked Underwater GPS / BlueROV2 Integration Kit provides a few components to make a seamless connection between the BlueROV2 system and the Water Linked system.
The world's most affordable high-performance ROV$2,989.00 – $4,939.00 Add to Cart -
Penetrator Wrench
For use with all M10 penetrators$13.00 Add to Cart -
RETIREDRevision Coming Soon!
Water Linked Underwater GPS Explorer Kit (Retired)
Robust acoustic positioning for ROVs and other subsea usesAdd to Cart -
Commonly used on the BlueROV2 and other products$6.00 Add to Cart
Installing the Locator-A1 on the BlueROV2
You will need to install the Analog Locator (A1) on the BlueROV2 using components from the Integration Kit. The locator will use one of the spare cable penetrations in the back of the BlueROV2 and will connect to the spare green and white twisted pair in the tether.
Removing a Blank Penetrator
Install Locator-A1 Penetrator
To install Locator-A1 into the end cap, you will need the following parts and tools:
- 1 x Locator-A1 with pre-installed cable penetrator
- 1 x Penetrator Nut (Black)
- 1 x Penetrator O-ring
- 1 x Isopropyl Alcohol Wipe
3. Install the O-ring onto the Locator-A1 cable penetrator.
4. Install the Locator-A1 cable penetrator on to the end cap in the hole you previously removed the blank penetrator from. Tighten to finger tight, then use the provided wrench to tighten it an additional ~1/16 of a turn. If you can’t loosen it with your fingers, it is tight enough.
5. Using the pre-crimped header pin connector on the Analog Locator, connect the locator wires (green/white) to a spare twisted pair of the tether (green/white).
Mounting the Locator-A1 to the BlueROV2 Frame
To mount the Locator-A1 to the BlueROV2 frame, you will need the following parts and tools:
- 1 x Aluminum Locator-A1 mounting bracket (2 halves)
- 4 x M3x16 socket head cap screws
- 2 x M5x12 button head cap screws
- 1 x 3 mm hex driver
1. Route the locator to one side of the ROV.
2. Attach the included aluminum mounting bracket to the Locator-A1 using the M3x16 socket head screws.
3. Secure the mounting bracket to the existing holes on the ROV frame.
Modifications inside the Water Linked Box
Inside the Water Linked box, we’ll be adding a Fathom-X tether interface board and a few cables to make integration seamless. This Fathom-X board will be added in addition to the Fathom-X board that is already used in the FXTI. The two boards are connected in parallel to the same twisted pair, putting the ROV, topside computer, and Water Linked box on the same computer network.
Here’s a diagram of what we’ll be connecting inside the box:
1. Remove the backing from the red 3M VHB tape on the back of the Fathom-X mount.
2. Install the Fathom-X board in the Water Linked box as shown below.
3. Unplug the Ethernet cable from the connector on the side of the box, route underneath the Water Linked board, and plug into the Fathom-X module.
4. Remove the Ethernet bulkhead connector from the side of the box. Remove the protective cap from that connector for reuse with the new connector.
5. Install the new bulkhead connector into the same hole, making sure the circle on the connector body is facing upwards. Replace the protective cap.
6. Using a small flathead screwdriver, connect the red and black wires to the positive and negative tether input terminals on the Fathom-X board.
7. Next, unplug the small A1 plug from the top right corner of the Water Linked board. Plug in the new A1 plug and leave the original one hanging loose.
8. Plug the Fathom-X power cable into port D5 or D6 on the Water Linked board. Then connect the ferrules on the other ends of those wires to the positive and negative power input on the Fathom-X board (black terminal block).
9. Add a zip tie to the wiring harness to keep all wires tidy.
Nice job! You’re done with modifications to the Water Linked box. Up next, we’ll show you how to connect the box to your ROV.
Modifications to FXTI/Topside Box
If using an FXTI (recommended method)
The connections made inside the FXTI will connect the ROV, Topside Computer, and Water Linked systems to each other. Here’s a high level diagram of what that will look like:
The connections are made on the Tether Connection PCB on the FXTI Electronics Tray and connecting the green Locator-A1 wires.
1. Remove one of the black plastic FXTI plugs from one of the auxiliary ports.
2. Thread the Water Linked Box to FXTI Cable into the open port and secure in place with the 3D printed spacer and black penetrator nut.
3. Connect the blue and blue/white wire pair into the FXTI Tether Connection PCB matching the orientation of the pre-installed blue and white wire connections.
4. Connect the green and green/white Locator-A1 wire pair into the green and white pair on the Binder connector pigtail, matching colors.
5. Reassemble the FXTI box.
If using the terminal block and a Fathom-X (depreciated method)
The connections made near the topside Fathom-X interface and topside computer will connect the ROV, Topside Computer, and Water Linked systems to each other. Here’s a high level diagram of what that will look like:
These connections are made on a terminal block with a few provided wires. Note that this isn’t the nicest solution in the world, using an FXTI as shown above yields a much cleaner installation. Below is a diagram of how the components are connected together along with step by step connection instructions.
1. Connect the red and black wires to the topside Fathom-X board. White and blue heatshrink is used to show the functional connection to the other twisted pairs.
2. Connect the tether blue/white and green/white pairs to the terminal block, matching the existing blue/white and green/white pairs. Plug the wires from the black Integration Kit cable into the header connectors, matching colors.
1. Configure the Water Linked system with a static IP address of 192.168.2.94 according to the Network section of the Water Linked Documentation.
2. Connect the topside computer to the FXTI.
3. Follow the Quickstart from the Water Linked Documentation for:
- Powering the Water Linked box.
- Calibrating the IMU.
- Deploying receivers.
- Making Receiver-D1 connections to the box.
4. To configure the receiver location Water Linked Underwater GPS system, navigate to http://192.168.2.94/#/receivers in your browser. Please refer to the Receivers section for further information on configuration.
5. Power on the BlueROV2 and dive so the Locator-A1 is submerged a few inches below the surface.
6. If everything is operating correctly, you should now find an ROV position on the map in QGroundControl. The ROV position is indicated by a BlueROV2 image. The position of the surface vessel or Water Linked Master Electronics box is indicated by a red arrow. The small ‘H’ icon indicates the ‘home position’, the location of the ROV’s first GPS lock.
Software Update
Check the Water Linked system for available software updates. You can check the Underwater GPS software version at 192.168.2.94/#/about. The update process is documented in the Software Update section.
