Buoyancy Calculator
This calculator finds the buoyancy of an object based on its displacement. It also uses the object weight or density to find the net buoyancy.
Calculator
(success) Enter volume followed by unit. (e.g. "0.1 m^3" or "20 in^3")
(success) Enter weight or density followed by unit. (e.g. "2.1 kg" or "12 lb/ft^3")
Buoyancy Output:
Net Buoyancy
0.66 kg
661.83 g
1.46 lbs
23.35 oz
Buoyancy
0.82 kg
819.33 g
1.81 lbs
28.9 oz
Weight
0.16 kg
157.5 g
0.35 lbs
5.56 oz
Average Density
192.22 kg/m3
0.19 g/ml
12 lbs/ft3
0.11 oz/in3
Densities of Common Materials
Material Density (click to use above)
Acrylic1180 kg/m373.66 lbs/ft3
Aluminum2712.63 kg/m3169.34 lbs/ft3
HDPE950 kg/m359.31 lbs/ft3
Polycarbonate1210 kg/m375.54 lbs/ft3
Subsea Buoyancy Foam192 kg/m311.99 lbs/ft3
Stainless Steel7861.1 kg/m3490.75 lbs/ft3
UHMW Polyethylene945 kg/m358.99 lbs/ft3
Water, fresh999.97 kg/m362.43 lbs/ft3
Water, salt1024 kg/m363.93 lbs/ft3
Learn More and Explore
This calculator uses the js-quantities library by gentooboontoo for unit conversions.
Interested in exploring more? Check out these products:
