This is a spare Vent Plug for the Enclosure Vent and Plug. It tightens into the vent penetrator and has dual O-rings for a reliable seal.
Vent Plug
$4.00
Have you misplaced your Vent Plug for your Enclosure Vent and Plug? No problem!
This is the old version of Vent Plug and is only compatible with the previous version of the Enclosure Vent and Plug (red bulkhead). It is not compatible with the current version of the M10 Enclosure Vent and Plug (black bulkhead).
- 1 x Vent Plug
- 2 x Vent Plug O-Rings
This is the specifications for the complete Vent product.
Parameter | Value | |
Recommended Through-Hole Diameter | 10 mm | |
Bolt Threading | M10 x 1.5 | |
Bolt Length | 25 mm | 0.98 in |
Bolt Head / Nut Diameter | 18 mm | 0.71 in |
Wrench Flats | 16 mm | 5/8 in |
Bolt O-ring | AS568-013 Buna-N 70A | |
Plug O-rings | 2mm Wide, 6mm ID, Buna-N | |
Maximum Tested Depth | 1000 m | 3280 ft |
VENT-M-PLUG-10-A-R3 (.zip)
31 March 2015
- R1 – Initial release
6″ and 8″ Series Non-Locking Watertight Enclosure (WTE) Assembly
Learn the basics of assembling a Non-Locking Watertight Enclosure (WTE)!
WTE Vent Assembly Guide
Quickly assemble a vent for your WTE project!
