$5.00
These plastic mixing tips are for use with Thixotropic Potting Compound and the Dispenser. They mix the epoxy as it is dispensed, ensuring an even mixture and minimal bubbles.
Out of stock
Join the waitlist to be emailed when this product becomes available
SKU: POTTING-P-MIXING-TIPS-QTY10-R1-RP
HS Code: 8424.89.9000
These epoxy mixing tips are used with the Potting Cartridge Dispenser to mix two-part compounds as they are dispensed. This ensures an even mixture and minimal bubbles introduced during the process. The narrow tip can be used to apply the epoxy directly but also fits most “luer” tips for fine epoxy application.
We use these tips every day when potting cable penetrators and other connections. They are one-time use and should be disposed of after each use.
  • 10 x Plastic mixing tips
6 September 2018
  • R1 – Initial Release
Potting a Cable Penetrator
Learn to pot the perfect penetrator to pass a cable into your watertight enclosure!
Blue Robotics Forums – Potting
You May Also Need
