$58.00
Subsea Buoyancy Foam machined specifically to fit in the BlueROV2 Heavy add-on fairing. Increases vehicle stability and lifting capacity.
24 in stock
SKU: BR-101121 Categories: ,
HS Code: 3920.61.00
Country of Origin: USA
LAST-A-FOAM® R-3318 is a machinable, hydrostatic pressure-resistant foam that provides buoyancy underwater. The closed-cell structure is engineered to resist penetration by water. Due to its pressure resistance to many fluids and resins, it is also used in resin-transfer molding as a core material. LAST-A-FOAM® R-3318 semi-submersible foam is optimal for shallow to mid-water underwater robotics applications.
This particular size is machined to fit perfectly into the BlueROV2 Heavy add-on fairing to increase vehicle buoyancy. This adds more stability and payload capacity to the ROV.
R-3318 is manufacturer rated to 210 meters operation depth when uncoated.
Features
  • Easy to machine, coat, and paint
  • Excellent compressive and insulation properties
  • Resistant to hydrostatic pressure
  • High impact resistance
  • Biologically Inert
  • Oil, grease, and solvent resistant
  • Cost-effective solution
  • Does not rot or decay
  • Performs in freshwater or saltwater
  • Compatible with many types of adhesive
Features
  • 1 x Machined R-3318 Buoyancy Foam for the BlueROV2 Heavy Add-on Fairing
Physical
Density288 kg/m318 lb/ft3
Specific Gravity0.29
Tested Depth (Uncoated)300 m984 ft
Tested Depth (Coated)488 m1600 ft
heavy-buoyancy-2view
BROV2-HEAVY-FILES (.zip)
Documents
R-3318 Material Safety Data Sheet (MSDS) (General Plastics)
Compatible Foam Adhesives & Sealants (General Plastics)
18 July 2023
  • BROV2-HEAVY-P-BUOYANCY-R1-RP SKU changed to BR-101121
27 February 2018
  • R1 - Initial release
