Aluminum End Cap with 15 Holes (6″ Series)
$44.00
This aluminum end cap with 15 holes is for use on the 6″ Series Watertight Enclosure.
SKU: WTE6-M-END-CAP-15-HOLE-R1-RP Category:
HS Code: 3923.50.00
This aluminum end cap with 15 x 10mm holes is for use with Watertight Enclosure for ROV/AUV (6″ Series).
If you’re looking for a complete set of parts for an enclosure, we highly recommend using the enclosure configurator here.
  • 1 x Aluminum End Cap with 15 x 10mm holes
  • 10 x M3x12 screws
MaterialAluminum 6061-T6
Surface FinishHard Anodized Black
Weight in Air339 g 0.75 lb
Depth Rating 65 m 213 ft
WTE6-M-END-CAP-15-HOLE-R1 (.zip)
27 April 2017
  • R1 – Initial release
Tutorials
Assembly Instructions
Watertight Enclosure Vacuum Testing Tutorial
