Aluminum End Cap with 5 Holes (4″ Series)
$20.00
This aluminum end cap with 5 holes is for use on the 4″ Series Watertight Enclosure.
SKU: WTE4-M-END-CAP-5-HOLE-R1-RP
HS Code: 3923.50.00
This aluminum end cap with 5 x 10mm holes is for use with Watertight Enclosure for ROV/AUV (4″ Series). We designed these end caps to have a greater depth rating than the clear acrylic end caps. Depth rating to be determined.
  • 1 x Aluminum End Cap with 5 x 10mm holes
  • 6 x M3x12 screws
MaterialAluminum 6061-T6
Surface FinishHard Anodized Black
Weight in Air165 g 0.36 lb
Depth Rating --
WTE4-M-END-CAP-5-HOLE-R1 (.zip)
28 December 2016
  • R1 – Initial Release
Learn the basics of assembling a Watertight Enclosure (WTE)!
Using the Vacuum Test Plug
Ensure the o-ring seals are good on our WTE with this quick test!
