Watertight Enclosure for ROV/AUV (4″ Series)
This configurable watertight container is great for use on ROVs, AUVs, and other marine robotics applications. Modular end-caps give you options – flat end-cap and end-caps with holes for cable penetrators.
SKU: WTE4-ASM-R1-VP
HS Code: 4009.12.00
This customizable watertight enclosure is perfect for use on ROVs, AUVs, scientific instruments, sensors, and other subsea applications. It is designed for long-term high pressure submersion in the ocean environment. This enclosure is part of the 4″ Series and has a 4″ inner diameter. A variety of options ensures the right enclosure for your needs.
Features
  • Interchangeable end caps
  • Double O-ring sealed flanges
  • Cast acrylic tube rated to 100m depths
  • Aluminum tube rated to 400m depth
  • Inner mounting holes on CNC aluminum flange
  • Compatible with our cable penetrators
WTE4-ASM-R2 (.zip)
31 March 2015
  • R1 – Initial Release
Learn the basics of assembling a Watertight Enclosure (WTE)!
Using the Vacuum Test Plug
Ensure the o-ring seals are good on our WTE with this quick test!
Support Community
