$10.00
This 200g (7 oz) lead ballast weight is coated, compact, and has a screw hole for easy mounting.
SKU: BALLAST-200G-R1-RP
HS Code: 2603.00.20
This 200g (7 oz, 0.43 lb) lead ballast weight is designed to be low-drag and easy to mount on your ROV or AUV. A hard black coating protects the weight and prevents direct contact with the water. The countersunk mounting hole is perfect for a #8 or 4mm screw diameter.
  • 1 x 200g Ballast Weight
  • 1 x 8-16 Thread, 5/8″ Long, Thread-Forming Screw
Physical
Weight in Air193 g 6.8 oz
Weight in Water175 g6.2 oz
BlueROV2 2D
31 August 2016
  • R1 – Initial Release
