Customizable Cast Acrylic Tube (2″ Series)
$0.13 / mm
This optically clear, cast acrylic tube is for use with the 2″ Series Watertight Enclosure. Sold by the millimeter.
This optically clear, cast acrylic tube for use with Watertight Enclosure for ROV/AUV (2″ Series).Product Description
This optically clear, cast acrylic tube for use with Watertight Enclosure for ROV/AUV (2″ Series).Contents
- 1 x 2″ Series Cast Acrylic Tube (customizable length)
Parameter | Value | |
Material | Clear Cast Acrylic | |
Surface Finish | Polished | |
Weight in Air | - | - |
Depth Rating | - | - |
9 July 2015
- R1 – Initial release
Learn the basics of assembling a Watertight Enclosure (WTE)!
Using the Vacuum Test Plug
Ensure the o-ring seals are good on our WTE with this quick test!
