Thruster Disassembly/Re-Assembly
You might need to take apart your thruster from time to time. Here’s how!
- 1 x 1.5 mm hex key
- 1 x 2 mm hex key
- 1 x 2.5 mm hex key
- 1 x #1 Phillips head screwdriver
Instructions
1. Remove the four phillips-head screws from the outside of the nozzle.
2. Remove the nozzle from the rest of the motor and set aside.
3. Using the 2.5 mm hex key, remove the screws securing the nose cone.
4. Remove the nose cone and set aside.
5. Manually turn the propeller until the shaft collar set screw is aligned with the notch in the plastic. Using the 1.5 mm hex key, loosen the shaft collar set screw.
6. After being used in water, the shaft collar can be difficult to remove. Do not try to pry it up. Instead, pull on the propeller from the opposite side to remove the shaft from the shaft collar.
7. Remove the propeller screws from the rotor with the 2 mm hex key and pull the propeller away from the rotor.
8. Repeat these steps in the reverse direction to reassemble the thruster.
Adam
Adam is a mechanical engineer at Blue Robotics. He started his journey in marine robotics as part of a high school MATE ROV team, eventually placing 1st at the International Competition! He joined Blue Robotics as our first intern in 2015 and then full time in 2016. Since then, he has designed a number of our coolest products and is our resident thruster expert!
