Motor Disassembly/Re-Assembly
Disassembly of the M100 and M200 motor is simple and should only take a minute!
Instructions
1. Loosen the set screw from the shaft collar at the bottom of the motor.
2. Remove shaft collar. If it seems stuck, pull the rotor away from the base to pull the shaft out of the collar. Do not pry the shaft collar.
3. Remove the rotor assembly.
Repeat these steps in the reverse direction to reassemble the motor.
Adam
Adam is a mechanical engineer at Blue Robotics. He started his journey in marine robotics as part of a high school MATE ROV team, eventually placing 1st at the International Competition! He joined Blue Robotics as our first intern in 2015 and then full time in 2016. Since then, he has designed a number of our coolest products and is our resident thruster expert!
