O-Ring Flange (4″ Series)
$29.00
This flange has a double O-ring seal that fits the tube for the 4″ Series Water Tight Enclosure. Comes with O-rings.
Only 21 left in stock (can be backordered)
SKU: WTE4-M-FLANGE-SEAL-R3 Categories: ,
This flange has a double O-ring seal that fits in the tube of the Water Tight Enclosure for ROV/AUV (4″ Series). The modular design allows a variety of end-caps to be attached to the flange.
Outer Diameter 4.5 in 114 mm
Inner Diameter 3.5 in 89 mm
End-cap Holes 6 x M3
Inner Mounting Holes 4 x M3
