Aluminum End Cap with 10 Holes (4″ Series)
$24.00
This aluminum end cap with 10 holes is for use on the 4″ Series Watertight Enclosure.
In stock (can be backordered)
SKU: WTE4-M-END-CAP-10-HOLE-R1 Categories: ,
This aluminum end cap with 10 x 10mm holes is for use with Watertight Enclosure for ROV/AUV (4″ Series). We designed these end caps to have a greater depth rating than the clear acrylic end caps. Depth rating to be determined.
  • 1 x Aluminum End Cap with 10 x 10mm holes
  • 6 x M3x12 screws
Holes 10 x 10 mm
Thickness 0.24 in 6 mm
Weight 0.34 lb 156 g
Installed Weight in Water (Salt)
Finish Type 2 Hard Anodizing
