Clear Acrylic End Cap with 7 Holes (3″ Series)
$14.00
This clear acrylic end cap with 7 holes is for use on the 3″ Series Watertight Enclosure.
SKU: WTE3-P-END-CAP-7-HOLE-R1 Categories: ,
Clear acrylic end cap with 7 x 10mm holes for use with Watertight Enclosure for ROV/AUV (3″ Series). Tested up to 100m.
  • 1 x Clear Acrylic End Cap with 7 x 10mm holes
  • 6 x M3x12 screws
Holes 7 x 10 mm
Thickness 0.35 in 9 mm
Weight 0.12 lb 56 g
Installed Weight in Water (Salt)
Material Clear Cast Acrylic
