3in-alum-endcap-r2
3in-alum-endcap-side
Images are CC-NC-SA 4.0
Aluminum End Cap (3″ Series)
$10.00
This aluminum end cap is for use on the 3″ Series Watertight Enclosure.
SKU: WTE3-M-END-CAP-R1 Categories: ,
This aluminum end cap is for use with Watertight Enclosure for ROV/AUV (3″ Series). We designed these end caps to have a greater depth rating than the clear acrylic end caps. Depth rating to be determined.
Aluminum is much easier to machine than acrylic. If you’d like to drill your own holes, tap holes, etc., then this end cap is the way to go.
  • 1 x Aluminum End Cap
  • 6 x M3x12 screws
Thickness 0.24 in 6 mm
Weight 0.22 lb 100 g
Finish Type 2 Hard Anodizing
