3in-alum-endcap-4hole
3in-alum-endcap-4hole-side
Images are CC-NC-SA 4.0
Aluminum End Cap with 4 Holes (3″ Series)
$12.00
This aluminum end cap with 4 holes is for use on the 3″ Series Watertight Enclosure.
SKU: WTE3-M-END-CAP-4-HOLE-R1 Categories: ,
This aluminum end cap with 4 x 10mm holes is for use with Watertight Enclosure for ROV/AUV (3″ Series). We designed these end caps to have a greater depth rating than the clear acrylic end caps. Depth rating to be determined.
  • 1 x Aluminum End Cap with 4 x 10mm holes
  • 6 x M3x12 screws
Holes 4 x 10 mm
Thickness 0.24 in 6 mm
Weight 0.21 lb 94 g
Finish Type 2 Hard Anodizing
