Clear Acrylic End Cap with 2 Holes (2″ Series)
$8.00
This end cap with 2 holes is for use on the 2″ Series Watertight Enclosure.
Out of stock
SKU: WTE2-P-END-CAP-2-HOLE-R1 Categories: ,
This clear acrylic end cap with 2 x 10mm holes for use with Watertight Enclosure for ROV/AUV (2″ Series).
  • 1 x Clear Acrylic End Cap with 2 x 10mm holes
  • 6 x M2x10 screws
Holes 2 x 10 mm
Thickness .24 in 6 mm
Weight 0.03 lb 14 g
Installed Weight in Water (Salt) 0.0045 lb 2 g
Material Clear Cast Acrylic
