small-1-O
Watertight Enclosure FlangeWatertight Enclosure Flange
Images are CC-NC-SA 4.0
O-Ring Flange (2″ Series)
$19.00
This flange has O-ring seals that fit the tube for the 2″ Series Watertight Enclosure. Comes with O-rings.
SKU: WTE2-M-FLANGE-SEAL-R2 Categories: ,
Quantity Discount:
10-24: 10% off
25-99: 15% off
100+: 20% off
This flange has O-ring seals that fit the tube of the Water Tight Enclosure for ROV/AUV (2″ Series). The modular design allows a variety of end-caps to be attached to the flange.
Outer Diameter 2.25 in 57 mm
Inner Diameter 1.5 in 38 mm
End-cap Holes 6 x M2
Inner Mounting Holes 4 x M3
