Basic 30A ESC (w/ forward/reverse firmware) (Retired)
$25.00
This is the old version of this product. You can check out the updated version here.
A simple electronic speed controller for the T100 and T200 Thrusters.
Out of stock
SKU: BESC30-R1 Category:
An electronic speed controller (ESC) is necessary to run any three-phase brushless motor like BlueRobotics’ thrusters. This 30 amp ESC is sufficient for the T100 and T200 thrusters. The BasicESC no longer includes a 5V BEC.
Key Features
  • Simple, robust brushless electronic speed controller
  • High speed update rate up to 1,000 Hz.
  • Forward/reverse rotation direction for forward/reverse thrust
  • Open-source, reprogrammable firmware to allow custom changes
The firmware for this ESC is open-source and available on the BlueRobotics Github page.
You can also download the compiled hex file here:
afro_nfet_besc30_r1.hex
Specifications:
Voltage 6-17 volts
Current 30 amps
Power Connectors 3.5 mm male bullet connector
Motor Connectors 3.5 mm female bullet connector
Signal Pulse-width (PWM)
Max Reverse: 1100 μs
Stopped:       1500 μs
Max Forward: 1900 μs
Deadband:   1475-1525 μs
Length 2.0 in 50 mm
Width 1.0 in 25 mm
Thickness 0.4 in 11 mm
Weight 0.06 lb 27 g
You may also like…
