Fathom ROV Tether (Random Lengths)
$20.00$34.00
These are random lengths of the Fathom ROV Tether <25m, too short to sell on their own or with the BlueROV2. If you are looking for larger lengths, you can find them here.
This professional-grade neutrally buoyant tether combines rugged strength and durability with high-performance electrical characteristics for wide-ranging ROV and subsea applications.
Clear
SKU: FATHOM-TETHER-NB-4P-26AWG-R1-DD Categories: ,
Everyone loves surprises, right?! We have a bunch of random lengths of tether that are too short to sell on their own or with the BlueROV2, so we decided to make them available to you, at a super low cost! The fun part is you won’t know how much you’re getting until you receive your order, but you’ll definitely get the minimum length of whichever option you choose. These are perfect for MATE teams, prototyping purposes, or for any reason you aren’t in need of more than 25m!
The Fathom Tether is a high quality tether cable designed specifically for ROVs and other subsea applications. It is neutrally buoyant, has 350 lb breaking strength, and is embedded with water-blocking fibers to seal any leaks. The tether has a diameter of 7.6mm and is slimmer than the vast majority of comparable ROV tethers.
We put a lot of time into making sure that it has impeccable electrical qualities. The tether carries four unshielded twisted pairs (UTP) of 26AWG wire. These pairs are colored and arranged in the same fashion as a Cat5 networking cable including cross-talk resistance. Each pair is individually jacketed inside the cable to maintain reliable properties and minimize interference between each pair of wires.
The core of the cable contains Kevlar strands for strength and Dacron fibers for space filling. Both fibers are impregnated with waterblocking compound to block any leaks caused by nicks or rips in the cable. The high-visibility yellow polyethylene foam jacket resists abrasion and provides neutral buoyancy.
The stiffness of the cable is designed to be flexible enough to give plenty of freedom to your ROV, but stiff enough that it does not become tangled easily.
The capabilities of this tether are meant to provide design flexibility and a wide variety of uses.
  • 1 x Tether Cable (choose length above)
