Subsea Buoyancy Foam (With Minor Dings/Dents)
$75.20
Subsea Buoyancy Foam for use on ROVs, AUVs, and other marine robotics applications. This foam can be machined, glued, painted, and coated to build any size or shape of float that you want. This foam (R-3312: 24 in x 8 in x 2.5 in) has minor dings and dents.
Only 2 left in stock
SKU: FLOAT-R3312-R1/D&D Categories: ,
LAST-A-FOAMĀ® R-3312 is a machinable, hydrostatic pressure-resistant foam that provides buoyancy underwater. The closed-cell structure is engineered to resist penetration by water. Due to the pressure resistance to many fluids and resins, it is also used in resin-transfer molding as a core material. LAST-A-FOAMĀ® R-3312 semi-submersible foam is optimal for shallow to mid-water underwater robotics applications.
These subsea polyurethane foams support training operations for the International Space Station, providing buoyancy for assembly components in pools that simulate weightlessness.
Features
  • Easy to machine, coat, and paint
  • Provides buoyancy with depths to 300 ft uncoated or 600 ft coated
  • Excellent compressive and insulation properties
  • Resistant to hydrostatic pressure
  • High impact resistance
  • Biologically Inert
  • Oil, grease, and solvent resistant
  • Cost-effective solution
  • Does not rot or decay
  • Performs in freshwater or saltwater
  • Compatible with many types of adhesive
R-3312: Density 12 lbs/ft3 192 kg/m3
R-3312: Specific Gravity 0.19
R-3312: Tested Depth (uncoated) 300 ft 91 m
R-3312: Tested Depth (coated) 600 ft 182 m
Sizes Available
24 x 8 x 2.5 in
610 x 203 x 64 mm
Buoyancy (Lifting force)
14.0 lb
6330 g
Weight (in air)
3.73 lb
1694 g
